Old 02-26-2018, 09:19 PM   #1
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
First 1/4 mile run! Overkill supercharged!
First off thanks to Tracy Lewis for the invite out to bradenton motorsports park. I was going to meet and hang out with Storm and Tracy and a few others I really didnt plan on dragging the car just to see some others.
I did not have a helmet so Tracys Grandson drove my car. Which was really exciting since ive never heard or seen my car run anywhere from the outside.
My plan was to pull some timing in the 4000 RPM plus range @ around 8lbs of boost and up log run the return the timings back. But we just got the one run.
Also forgot to air out the rear tires so running 40psi heh.
Extremely satisfied with the results ! Oh yeah this also after 24k miles on the kit.
https://youtu.be/TDZrtpNG2Ik
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 02-27-2018, 06:31 AM   #2
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Congrats! First 6th gwn v6 in the 12s? (12.83)
Was that a 6 or 8 with the mustang?
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 02-27-2018, 08:45 AM   #3
Dustya
The mustang ran an 11.6 It was def an 8 with some some heavy mods had to be FBO.
And yes first gen 6 v6 in the 12's however the track tears the slips in half on test and tune and only gives you your half I was right lane so i don't have date time etc.. not sure they will count it on the 1/4 thread.
I see 12.5 pretty easy - To get to 11's I am going to need to be on e85 and probably 12-13lbs of boost. In march im going E85 for sure so we will see what it does with the aggressive timings you can run on E85 with the 10lbs im running now.
Old 02-27-2018, 09:14 AM   #4
Drives: 2016 camaro
Good stuff. I mean you got the vid and the slip as proof. I dont make the rules. But i acknowledge it
11's maybe with the right toque converter and some tweaks. Ive seen 4-6 tenths on converter additions alone.
Either way
Old 02-27-2018, 09:10 PM   #5
Dustya
Either way
Yeah a converter would be nice this run was also just smashing the gas no preloaded RPM - There is very little for the 8l45 though :-(.
Old 03-16-2018, 02:34 PM   #6
AJL13
Drives: 2017 Camaro RS
I am interested to see how this pans out long-term. I would need to see at least low 12s before dropping $8K on their kit, given the power they are claiming (366 whp).
AJL13 is offline   Reply With Quote
Old 03-16-2018, 03:49 PM   #7
GhostEye07
GhostEye07's Avatar
Drives: '16 Camaro 2LT RS
Very Nice run! Going to try and hit 12.8 N/A before I get a SC. I'm at 13.1 so I'm almost there xD
2016 Camaro 2LT RS E85 V6
Build Thread | My Instagram
GhostEye07 is offline   Reply With Quote
Old 03-16-2018, 04:39 PM   #8
Dustya
366whp is stage 1 kit which Is 6500.. you wont get into low 12s on 360 whp unless you lose alot of weight.
12.8 was detuned 40psi of air and just a hammer of the gas in 85 degree weather.. there is some nice changes coming and ill be going for more runs here shortly.
Old 03-16-2018, 05:03 PM   #9
AJL13
Isn't 366 whp close to SS territory, or is my drivetrain loss math total garbage?
Also, is this your daily? If so, what kind of mpg are you seeing?
Old 03-16-2018, 06:37 PM   #10
Reximus
Drives: 2lt rs lgx
Nope, I believe the SS puts most of it's HP to the wheels. The v6 has a considerable loss in power to the wheels.
Reximus is offline   Reply With Quote
Old 03-16-2018, 07:19 PM   #11
Dustya
SS stock is 455hp most dyno in the 390-400 range some a bit lower some a bit higher. The SS has a stronger Tranny and Differential though.. I think GM overshot on the v6 crank HP because most are dyno stock around 250 mine was super low at 238 some as high as 260 even at 260 though thats over 20% Thats over 20% drivetrain loss..
As for daily yes I have over 25k miles on the supercharger kit already install was finished june of last year I DRIVE ALOT.. I get anywhere from 29-32mpg highway with cruise on 77.. my 400 mile average is usually about 26mpg and I cannot keep my foot out of it at stop lights etc cuz it feels and sounds so good lol.
Old 03-17-2018, 11:03 PM   #12
DirectTo
DirectTo's Avatar
Drives: Sold!
Aside from the transmission, the drivelines of a manual V6 are a lot of the same parts as the V8 if I recall correctly. Obviously gearing plays into any comparison, but how is the V6 (again, manual) losing that much more power? Or am I mistaken about components?
DirectTo is offline   Reply With Quote
Old 03-19-2018, 09:01 AM   #13
sykb47l
sykb47l's Avatar
Drives: 73' VW Bug
Why didnt you just wear the helmet?
sykb47l is offline   Reply With Quote
Old 03-19-2018, 10:58 AM   #14
Dustya
I wont wear anyones headphones helmets earbuds earmuffs etc.... lol But I will be at the track soon, Like I said i wasnt even planning on having it run it just kind of happened. Went to the event to hang out with Nacol and Tracy.
