10-31-2018, 05:50 PM | #57 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
11-02-2018, 02:46 PM | #58 |
555r. No launch control, 1800rpm. I bet it has a 3.4 in it easy.
2016 NFG 1SS A8
11-02-2018, 06:01 PM | #59 |
I think we really need access to the CCM or whatever controls traction control. Its just hard to believe we couldn't get launch control to work for us, there's no way a human can be better and more consistent than a computer.
11-03-2018, 06:02 PM | #60 |
I tried launch control today. The car won't hold...just wheel hops and tries to spin. It wont let me set the 0-60 timer because it thinks the car is moving... So it's only good for stock power. Dont really need it anyway...with these tires this setup will go 3.4-3.5 time after time. It's consistent enough to bracket race. Quick little first gear burnout, brake stall to 2k rpm, let off brake and put the pedal to floor....hooks and goes Everytime.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 11-03-2018 at 06:12 PM. |
11-03-2018, 06:45 PM | #61 | |
You're saying the tires won't hold when trying to brake stall with launch control? That's weird I wonder how you are getting enough traction to get 3.6 seconds, but it won't hold the torque from launch control? I'm still at a best of 3.9 seconds. I swear one time I got 3.8, I get mostly 4.0 or 4.1 I think its heavily dependent on how clean the road is, whether its got sand or gravel, or its freshly paved. Then probably the temp of the asphalt and tires. I just hate trying to burnout and warming the tires, I just see money flying away haha As far as I know the timer starts instantly, so its not including roll out. I'm pretty sure the stock quoted time of 4.0 is with rollout. Now I've heard rollout usually takes about .2-.3 seconds off the 0-60, and I think I remember looking at my HP tuners log and adjusting for the rollout and getting I think like 3.6 seconds. |
11-03-2018, 07:18 PM | #62 | |
2016 NFG 1SS A8
11-04-2018, 06:40 PM | #63 |
Drives: Nothing fun, currently. Join Date: Aug 2016
11-04-2018, 06:42 PM | #64 |
My car is not a daily, but I would rather drive these daily then the stock run flats...much nicer driving tire but they will only last 10-15k miles if your easy on them.
2016 NFG 1SS A8
11-07-2018, 06:18 PM | #65 |
But you could probably run a harder tire up front and only have to replace the rear. Also do you have to sacrifice a lot in handling? from the tire being less stiff?
11-07-2018, 08:03 PM | #66 |
Drives: Currently Looking for 2019 SS Join Date: Dec 2017
Newbie here, how does one get the 0-60 timer? Is it only on the 2ss?
11-08-2018, 12:05 AM | #67 | |
Car handles fine with the 555r's. Best drag radial for all around driving. I have had all of them.
2016 NFG 1SS A8
11-09-2018, 09:52 AM | #68 | |
No 1SS has it too, I think it's under the "perf" category on the screen. Spend a little time searching for it and you'll find it.
2017 Camaro 1SS - Bright Yellow - 6spd
11-10-2018, 06:11 PM | #69 |
Drives: 2K17 SS Camaro Join Date: Jun 2009
3.9 for the ZL1. all nannies on, 99 degrees outside. (Mexico)
4.1 for the SS at the track, 1.86 60* (Bone Stock on Nitto G2's)
Duane
2017 50th SS 12.28@114 Bone Stock 12.005@117 Bone Stock with a DR 2018 ZL1 A10, no times, wife won't let me race it. |
