05-02-2016, 09:31 PM | #1 |
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1 Join Date: Oct 2009
Anybody have a Lsx 376 b15
Thinking of going with this. Currently have a L99 with a maggie, headers, adm fpcm and zl1 pump. Last fall my cat clogged and had some detonation. Put a camera down the spark plug hole, one of the pistons has a small chunk missing.
Looking to put down 600 to the wheels. Is the extra 100 lbs noticeable? Adm seems to use this engine with good results. |
05-02-2016, 09:34 PM | #2 |
Andy is receiving my b8 in the mail
Tommorow. He said unless your not happy with 650-700 at the wheel there's no reason for the b15. And making me an unbeatable deal at that. I checked and the actually shipping weight of the b8 was only 40lbs more than the ls3. 513lbs shipping vs 474 shipping weight on the ls3. I was at 565 before. Dropped a connecting rod. I'm just doing the stock b8 with a stg3 BTR cam on 8psi looking at 600-625 SLP supercharged 2013 SS/RS 1LE VR Full front half protected by Xpel PPF Instagram:@Failshift 565hp/560tq @8.6psi 1LE Owners Group: https://www.facebook.com/groups/559684050767758/ |
05-02-2016, 10:01 PM | #3 |
Drives: 2006 Z06 Join Date: Oct 2010
That weight is way off. That much be just the short block compared to an ls3 long block. LSX block is well over 100lbs heavier. Yes it is noticeable. I wouldn't consider an iron block for less <1000rwhp.
Nick
Corvette Z06 -1200ish rwhp |
05-02-2016, 10:02 PM | #4 |
Both long blocks.
05-02-2016, 10:08 PM | #5 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
LSX block is more like 80lbs more than LS3 block.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
05-02-2016, 10:09 PM | #6 |
I know what it's supposed to be. I'm just simply quoting the exact shipping weights of both long blocks
05-03-2016, 06:19 AM | #7 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
I have an iron block. The nose of the car dropped noticeably after the install so I know it's HEAVY
05-03-2016, 08:39 AM | #8 |
Drives: Camaro Join Date: Mar 2013
I got the first LSX B-8 ADM package installed by Andy in a 2013 SS. 659 on 93 and 694 on 110. Over the next 3 years, I have 8000 miles on the car 1/8 of a mile at a time. Motor is doing great but on my second clutch.
No need to go to the B-15 unless you are going crazy boost. |
05-03-2016, 10:43 AM | #9 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Do you want a shortblock or longblock? Either way i would get an aluminum block built from texas speed, LME or one of the other big Ls engine builders. Cheaper, less weight and can be built with better internals than a b8 or b15.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
05-03-2016, 11:43 AM | #10 |
Andy also sells short blocks for 4995 416-418 all forged.
05-03-2016, 11:46 AM | #11 |
Thanks for all the info.
05-03-2016, 11:46 AM | #12 |
Are you close to lewisville?
05-03-2016, 11:58 AM | #13 |
No, Iowa. Did you notice a handling difference with your 1le and iron block?
05-03-2016, 11:59 AM | #14 |
Don't have it yet. It will be delivered to ADM today. Hopefully have the car back next week. But I'll have a bit more power to. Optimizing it. And doing a Stg3 BTR. Before I was just a bone stock ls3 with the SLP blower on 8psi very simple supposed to be "safe" setup
