04-22-2021, 05:58 PM | #15 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Coby Shield had the full DSC system on his SS 1LE. I have the DSC Sport Controller for the factory mag shocks. I love being able to tweak the understeer bias based on the tires I'm running, but the software is not user friendly and DSC doesn't provide tuning support or help. You are left to fend for yourself.
Compared to the ZL1 1LE with DSSV, my car has better weight transfer in brake zones and corner exit grip. The ZL1 1LE is more predictable and has a higher threshold of yaw. I consider them more equivalent than an upgrade.
04-23-2021, 06:11 AM | #16 | |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Being able to fine tune some of the damping characteristics would be huge. Even though it is expensive, if you can get tuning that is close to coil overs, not a bad way to go. I've watched a few videos on the software...yikes. Ken |
04-23-2021, 06:22 AM | #17 | |
With your car, a 46 is for sure a possibility. My bone stock (literally the day after I bought it, no alignment, etc.) SS1LE went a high 1:51...my goal is a 47 with it this summer once it is set up. Ken |
04-23-2021, 11:20 AM | #18 | |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
Anyhow, back on topic, heh. For what it is, the DSSV setup is very good. If you aren't planning to get really aggressive with wheel/tire fitment, I think the easy upgrade is to run the A10 DSSV rears. They were valved softer, you can get them from rockauto for a decent price, and they really fix everything I disliked about the stock DSSV setup. |
04-23-2021, 05:12 PM | #19 |
Drives: ZL1 1LE Join Date: Oct 2016
That's an interesting idea. I actually remember an early review of the ZLE where Pobst commented on the rear just being a bit too oversprung.
My thought process for an upgrade was really just to finally take the step into turning this car into a 100% track car. To actually be able to set up the suspension for an increase in aero and different tires.
04-23-2021, 05:15 PM | #20 | |
talk to the blue dragon guys out in texas they have one of the most modified zl1 1le i have ever seen
04-23-2021, 08:22 PM | #21 |
Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
04-24-2021, 07:40 AM | #22 |
Drives: Camaro 1ss Join Date: Nov 2019
99% sure those guys are on Detroit speed coilovers.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
04-24-2021, 07:49 AM | #23 | |
04-24-2021, 06:00 PM | #24 | |
aka BeastZL1
This is why going to an electronically adjustable shock setup is interesting. You are going from fixed to fixed setup and it might not be desirable.
04-26-2021, 11:39 AM | #25 |
which are just relabeled jrz coilovers
ive done so much research on suspension and coilovers since i got my car afe power /pfady was suppose to do coilovers for my car which were awesome on the 5th gens and corvettes but never happen so thats why ive had to do some more research on my side
04-30-2021, 08:27 PM | #26 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
SPL Parts talked about them a lot because they have all the SPL suspension parts on that car too
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
04-30-2021, 09:23 PM | #27 | |
Drives: 1985 Oldsmobuick Join Date: Oct 2012
05-01-2021, 02:21 AM | #28 |
Drives: 2017 SS 1LE Join Date: Mar 2016
This may be an extreme long shot BUT if I can find a decent contact with them over here (that speaks english lol) I'm going to try and see if I can get KW to adapt their version 4 or 5 coilovers for our cars. The only thing they have listed for 6th gens currently is their V3 which is only single adjustable so I don't think that's worth the trouble. They just released a V5 kit for C8, that's is ideally what I would want since they are 4-way adjustable but I'm not going to hold my breath. Gonna poke around at some of the shops up at the Ring soon and see if anyone has a good contact at KW.
IG: @NC_M1SS1LE
