05-28-2019, 06:13 PM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2018
BMR rear adjustable sway bar end links w/hardware
I just purchased a BMR drag bar setup and have upgraded all my end links to the Hotchkis adjustable end links. These come with all new hardware plus a few extra pieces as shown in the pics.
Asking $100 shipped/paypaled anywhere in the USA. Thanks, Kevin |
06-01-2019, 06:45 AM | #2 |
Anyone?
Kevin |
06-05-2019, 11:59 AM | #3 |
Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6 Join Date: Dec 2016
whats the benefit of adjustable sway bar end links? use with upgrade sway or stock?
CamaroLIFE
06-14-2019, 05:46 PM | #4 |
From BMR:
"BMR’s heavy-duty adjustable end links are designed to reduce deflection normally seen with stock sway bar end links. End link deflection means reduced sway bar rate, leaving you with increased body roll and reduced handling ability. BMR’s will not deflect, giving you the full potential of the sway bar—no matter how hard you drive. The adjustable links give you the ability to easily correct sway bar geometry and working angles on lowered Camaros, as well as cars with adjustable sway bars. The adjustable end links give you the ability to preload the sway bar to fine-tune your suspension setup for any track. Combine this with BMR’s adjustable sway bars, and you can dial-in your car for the street or any track you may drive on." Still available if you are interested, Kevin |
06-14-2019, 10:44 PM | #5 |
$80 shipped?
Roto fab,stainless power works long tube headers,atak cat back exhaust,cat delete and dyno steve custom tune.
06-15-2019, 05:37 AM | #6 |
I can do that. Sending you a pm Slilly2012ss.
Thanks, Kevin |
06-15-2019, 08:18 PM | #7 |
Sold to Slilly2012ss.
Thanks Kevin |
