09-25-2021, 08:06 AM | #15 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
09-25-2021, 09:27 AM | #16 | ||
Drives: 1SS 1LE Join Date: Jul 2018
On the 9th 2% chance of rain so I signed up. On the 16th this. Usually run at 1:47 Last edited by Wontspeak; 09-25-2021 at 09:39 AM. |
09-25-2021, 12:19 PM | #17 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Those are the sizes I'd run on those wheels, and the PS4 is available in those sizes. And no, I don't see a reason to run spacers because those wheels have correct offsets for any SS (1LE or not) as they come.
Matt Miller
2020 SS 1LE Last edited by Msquared; 09-25-2021 at 04:20 PM. |
09-25-2021, 04:05 PM | #18 |
09-25-2021, 04:06 PM | #19 | |
Great info, thank you. I wasn't sure if the offset would work out or not. |
09-25-2021, 04:27 PM | #20 |
Yep, there's no difference in fender space between a plain SS and an SS 1LE. If it fits on an SS it will fit on an SS 1LE and vice versa.
Matt Miller
2020 SS 1LE |
09-26-2021, 08:03 AM | #21 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
09-26-2021, 12:34 PM | #22 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
F$&K that! If I showed up for an event and Mother Nature delivers a downpour my car stays on the trailer and I consider my entry fee a donation to the organization. Not much fun tooling around the track at 1/4 speed not to mention worrying about somebody else sliding into me. Shit happens.
09-26-2021, 01:59 PM | #23 | |
Norm
09-26-2021, 04:45 PM | #24 | |
09-27-2021, 11:43 AM | #25 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
https://www.camaro6.com/forums/showthread.php?t=485975 I met someone with an SS 1LE running SS wheels/tires on the street who would swap to stock SS 1LE wheels at the track and he had rubbed through the fender liner because he wasn't aware of this. |
09-27-2021, 09:31 PM | #26 | |
Something else went wrong with your friend's car to cause that rub-through. There's a TSB where some cars had the harness fall off its fastener behind the liner. When that happens, it falls down due to gravity and car movement and it start pushing the liner out into the tire. Happened to a friend of mine with stock rear 1LE tire sizes.
Matt Miller
2020 SS 1LE |
09-28-2021, 12:45 AM | #27 | |
I assumed that there would be less room between the wheel hub center and fender liner on the SS 1LE since it sits about 3/4" lower than a regular SS (according to this: https://www.camaro6.com/forums/showp...36&postcount=2 ), explaining why the stock tire has a smaller diameter than the stock SS tire but maybe that is incorrect? The spot that rubs through first is closer to the hub center than the top of the fender liner is regardless. |
09-28-2021, 07:49 AM | #28 | ||
Matt Miller
2020 SS 1LE |
Thread Tools | |
