Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 08-23-2020, 07:41 AM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
SD Card for PDR
Question: Please tell GM to start providing a formatted SD card with each car with a PDR. I've wasted hours formatting cards in different ways incl. FAT32 but the car still does not see the card. Thanks
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 08-23-2020, 09:17 AM   #2
h422694
h422694's Avatar
Drives: '16 Z06 7 Spd, 2024 High Country HD
Might be a bad drive in PC or car. I \'ve used several brands from several places and did not format them and they worked fine. I've also formatted some and only FAT32 worked. Max size is 32G unless recently changed.
Are you getting any messages from PDR?
h422694 is offline   Reply With Quote
Old 08-23-2020, 11:51 AM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, it says SD card not inserted.
I've tried two different cards in FAT32 and another format. Can the USB port be used for an SD card? I have a nice USB SD card read writer
'20 ZL1 1LE A10,
Old 08-23-2020, 01:31 PM   #4
h422694
h422694's Avatar
This is from the manual - FAT32 formatted SD card, Class 10 required, 8, 16, or 32 GB recommended. The SD card reader is below the instrument panel to the left of the steering wheel and just above the hood release.
I saw a ;ot of similar issues on another forum and most were resolved by correct formatting and using a Class 10 card. Also USB drive will not get recognized for PDR.
Old 08-23-2020, 01:39 PM   #5
turbo2ltr
turbo2ltr's Avatar
Drives: 2018 1SS 1LE
I bought this card, works perfectly.
https://amzn.to/3hqFPrx
2018 1SS 1LE Hyper Blue
turbo2ltr is offline   Reply With Quote
Old 08-23-2020, 06:26 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
I've been trying the SD reader in the console because the one you refer to is broken or something and I had to use pliers to get the card adapter out
'20 ZL1 1LE A10,
Old 08-23-2020, 06:42 PM   #7
turbo2ltr
turbo2ltr's Avatar
The reader on the left side of the dash, you push the card in and it clicks in flush. Then you push it in again and it pops out.
You are saying once installed, when you push it in it doesn't pop back out?
Might have a bent pin in the socket which could cause it both not to work and not to pop out.
I have never seen anything that would indicate you can use anything but that socket for the PDR SD Card.
Old 08-23-2020, 08:32 PM   #8
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
The centre console SD slot is for the Navigation SD(if you have navigation) or media storage(if you don't have navigation and swap the centre console one out with an adapter with SD slot).
As mentioned, the PDR slot is above the OBD2 port.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-23-2020, 08:44 PM   #9
h422694
h422694's Avatar
PDR will only use the one by the hood release and also pretty sure it needs to be a full size SD card, not a microSD with adapter. It's been a year or so but if I remember correctly the one in the console used to be for Navigation updates. I have a Z06 and C7 Corvettes only have the PDR reader. NAV updates are via USB in console.
The way these SD card readers work is you insert the SD card and push in until it locks. To remove it, you push it in and it will release and come back out enough that you can easily pull it.
If you originally used a microSD with adapter and the adapter is still in reader, I would carefully press it in like you were originally putting it in and that should release it if it's not damaged.
Good Luck.
Old 08-24-2020, 04:01 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
My car is on the way to HPE for additional mods so I can't try that port again for a few weeks
'20 ZL1 1LE A10,
