Old 04-14-2023, 10:31 AM   #1
Kerry
Drives: 2019 2SS Camaro
Half shafts cv axles zl1 convertible noise from rear
So can we use the cv axles from the convertible zl1 non elsd non 1le, to use as a type of upgrade to the ss?
I started getting a humming noise at 45 and 65 that got worse quick. Took the axles loose and there's a lot of play in the cv joint where it bolts to the diff. Where it goes into the wheel no play at all.
I understand there is in and out movement for suspension, this is back and forth or right to left like about 1/4 inch or more. Both axles. Im thinking this is where the noise is coming from.
i crawled under the car with it on the quick jack with it running and its definitely coming from the rear.
Kerry is offline   Reply With Quote
