Old 09-11-2018, 08:45 AM   #1
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
5th gen wheel question
Will the SS RS 5th gen rims fit on a 2018 Hot Wheels 2SS convertible? My brother has a set on his 5th gen for winter but is looking to upgrade to a 6th gen
artey34 is offline   Reply With Quote
Old 09-11-2018, 08:55 AM   #2
artey34
artey34's Avatar
This is what the offset calculator shows. Does this look right? Maybe a small spacer?
Old 09-24-2018, 08:48 AM   #3
artey34
artey34's Avatar
bump
Old 09-26-2018, 09:29 AM   #4
artey34
artey34's Avatar
I found a set of 5mm spacers. I dont want to stack spacers so will 5mm be enough? Or should I find a set of 10mm. Also found a set 15mm that would work
Old 09-26-2018, 10:50 AM   #5
SR 33
SR 33's Avatar
Drives: 2016 1LT - SIM
I did a test fit at one point. I think a 15 on the front put it right at the fender. Don’t remember which size on the rear
SR 33 is offline   Reply With Quote
Old 09-28-2018, 12:56 PM   #6
DailyFifty
Drives: 2017 Fifty 2SS M6 Coupe
Back rear is clear all day long. I have 275/40R20 on the rear of a 2017 2SS lowered 1.5" and it's fine.
Front is tricky with the strut cup. If diameter is too big there is no spacer in the world that will get you out of the way. If diameter is small enough you have a little bit of space to clear. My experience on the front is as follows.
Stock 245/40R20 on stock front wheel Fit fine
Stock rear wheel with 285/30R20 still cleared strut
Aftermarket 9" +35 wheel with 275/40R20 no go
Same aftermarket wheel with 255/30R20 tons of clearance
stock 245/45R20 from 5th gen should clear but will be very close to strut cup no mater how far you space it out.
DailyFifty is offline   Reply With Quote
