TireRack
Old 07-25-2017, 10:52 AM   #1
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
What do I need to hit 700-750whp?
--Update:
I've decided that I will most likely doing smaller ball bearing turbos for instant spool. I am now looking into the fuel system to run E85? Can anybody tell me the "theoretical difference" between running higher boost to achieve my HP goals on 93 versus lower boost on E85 to hit my HP Goals?
If I went the E85 route, what pieces would I need to complete the fuel system? Engine stuff is an unknown territory for me, but it looks like I will need a flex sensor and dual fore innovations 450 pumps. What will I need to support and control those pumps?
Really debating going F/I instead of my all NA build next year, I want to do all of the maintaince/reliability add ons when ripping this part and rebuilding. What is everything I will need? I know this is a pretty broad question but I am new to the F/I side of things. As far as the engine goes, I am thinking:
New lifter trays, lifters w/ bronze bushings or more durable bearings
Blower cam w/ 3 bolt
C5r timing chain
New oil pump (high pressure and not volume?)
Fuel pump potentially?
Injectors
Flex fuel sensor for e85
Pushrods
Springs
Head studs
New gaskets/seals
Long tube headers
Better oil coolers
D1SC kit?
Throw in any advice/comments that you have! Planning for next year!
Also, what will the stock 2014 1LE manual trans/rear end handle before I have to upgrade?
derieu is offline   Reply With Quote
Old 07-25-2017, 11:11 AM   #2
AGP Turbo
Drives: All things Turbocharged
We do 700whp on 100% stock LS3's on pump gas with our turbo systems. Your car already has the ZL1 pump so all we do in big injectors and a boost a pump for that.
Now if you want to go upwards of 800whp then a higher octane fuel like E85 is necessary. And to do a full flex fuel system you need a twin pump system with flex fuel sensor and bigger injectors. Still on 100% stock LS3 engine.
A supercharger will need a lot more mods since they are less efficient and will stress your engine 15-20% more.
AGP Turbo is offline   Reply With Quote
Old 07-25-2017, 11:16 AM   #3
jrhagen
Drives: Camaro
See my signature.
jrhagen is offline   Reply With Quote
Old 07-25-2017, 11:59 AM   #4
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
A supercharger will new a lot more mods since they are less efficient and will stress your engine 15-20% more.
Reason why I'm going turbo as soon as I can. Hopefully I'll make some of money back selling all the supercharger goodies
camarosspower is offline   Reply With Quote
Old 07-25-2017, 12:23 PM   #5
jeff657756
Drives: 2014 SS 1LE
My numbers with AGP base kit, AGP/Fore dual pump system on E60. Stock bottom end LS3 with cam. Not sure how much it would have made if we kept going.
684 604 @ 8 lbs
736 645 @ 9.7 lbs
824 716 @13.7 lbs
jeff657756 is offline   Reply With Quote
Old 07-26-2017, 02:34 PM   #6
sprayedv
Drives: 2012 CTS-V, 2010 Camaro SS
But turbos are soooo boring compared to a roots blower car.
2012 CTS-V: Cosmetic Chute.
sprayedv is offline   Reply With Quote
Old 07-26-2017, 03:43 PM   #7
Scotty D
Drives: 2014 1le 1SS CRMT
Why is that ???
Scotty D is offline   Reply With Quote
Old 07-26-2017, 03:53 PM   #8
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Yep.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 07-26-2017, 04:13 PM   #9
AGP Turbo
LOL
Old 07-26-2017, 04:26 PM   #10
jrhagen
Drives: Camaro
Interesting how nobody has addressed the trans, driveshaft, diff and axles yet.
My advice, upgrade them all and sell your stock parts before you grenade them.
Old 07-26-2017, 05:07 PM   #11
dreksnot
dreksnot's Avatar
We all were waiting for you to do that. Done! And, that is very good advice to sell them while in good condition. Nobody wants a bucket full of gear. So, save your lunch money and get it all done right the first time because breaking crap sucks (and having to fix it).
Old 07-26-2017, 05:12 PM   #12
jrhagen
Drives: Camaro
Old 07-26-2017, 05:14 PM   #13
jrhagen
Drives: Camaro
Additionally, if I had it to do over again, I probably would have gone twins. Just saying.
Old 07-26-2017, 05:39 PM   #14
AGP Turbo
It's never too late Toss an extra 300hp on your car, it's begging for it.
