11-10-2020, 02:18 PM | #1 |
ST43 PADS VS DTC50
talked to some 1le guys over the weekend as im looking into some new pads for next year and just wanted to get your guys take on both of these
what do you guys run and what do you guys think about both setups? dtc50 cheaper and doesnt last as long st43 more expensive and longer life im on 200tw treadwear tires btw and i have a zzp bbk which is ctsv3 calipers and 2 piece 1le rotors
11-10-2020, 02:30 PM | #2 |
Drives: 20 SS 1LE Join Date: Jun 2020
Also quite curious. I started with ST43 and they do seem to wear well but they have too much bite for me. Hard to modulate without constantly getting the fronts into ABS.
John Hale
multi time solo nats runner up :( |
11-10-2020, 02:33 PM | #3 | |
i have heard that about the st45 but not the st43 i know some people mix and match but i wasnt ever sure what the reasoning on that was
11-12-2020, 09:07 AM | #4 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
They were rough on rotors as well. They do last a very long time, but the heat will make your other components last much shorter. So not a good result. All imo. Cheers! |
11-12-2020, 10:32 AM | #5 |
hmm ok thanks for the feedback
11-12-2020, 11:31 AM | #6 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
YMMV, there is no best pad. You have to decide based on your driving style.
I absolutely love the ST43s and run em, no issues. I run them Front and back |
11-12-2020, 11:36 AM | #7 | |
do you drive your car to and from track and do you do any street use with it also ?
11-12-2020, 12:04 PM | #8 |
I go to/from easily on the ST43's. They have plenty of cold bite and don't squeak/dust as much as most track pads do. But they are a bit binary.
John Hale
11-12-2020, 12:05 PM | #9 | |
a bit binary? what do you mean by that
11-12-2020, 12:07 PM | #10 |
Driving style (as in depth of trail braking), venue type (as in cooling opportunities), ultimate pace, etc.
11-12-2020, 12:24 PM | #11 |
11-12-2020, 12:27 PM | #12 |
aww gotcha makes sense sounds like ill have to try em out myself what are you running trackclub?
11-12-2020, 01:38 PM | #13 | |
But i dont, as i make up for it under trail braking. Plus the value is good for my wallet and all consumables affected by extra heat. However, once i run thru my current supply i may give DS2500 a try as a slight step up from stockers and see how i like em. |
11-12-2020, 04:53 PM | #14 |
You are tracking on the HP1000's regularly? Aren't they good for 650 degrees max? I've gotten pad fade at fast autocrosses on the stock pads.
John Hale
