11-09-2020, 08:28 PM | #1 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
SS track day brake rotor heat shield question
With what I have at my disposal right now I can’t get these calipers off, that being said how bad would it be to run a track day with the tire deflectors removed, with the track control arm air guides, but with the street rotor heat shield?
11-10-2020, 11:02 AM | #2 |
i wouldnt recommend doing it especially if you are on stock brakes and fluid
11-10-2020, 11:25 AM | #3 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
If you still plan to run, definitely switch to a higher DOT 4 fluid if you haven't already (Castrol SRF, Motul 660, and Brembo HTC64T are the higher boiling point ones that come to mind) and take it a little slow if you're a seasoned driver that can push the car to it's limits and you should be fine. Can also brake early which still gives you time to slow down before the corners if you're concerned about overheating as well. Can even bring parts with you and possibly swap at the track if you can find someone that'll let you borrow the tools that you need, it's a pretty quick job that can be done before starting or by skipping a session.
2017 SS 1LE.
11-10-2020, 11:18 PM | #4 |
j1ss
Guys I was able to get the calipers off and swap to the track brake shields. They probably helped a lot but it still only took 4-5 laps to get them really hot, even in the rain.
The car has DOT4 motul 600 fluid in it https://m.youtube.com/watch?v=PMHdmCZbw74 Motul 660*** |
11-11-2020, 10:20 AM | #5 |
are you on stock pads and lines? before i swapped over to the zzp bbk kit i had motul 660 fluid stainless steel lines and powerstop track day pads and i never had any problems with overheating just wanted a better/bigger setup
11-11-2020, 06:42 PM | #6 |
j1ss
Stock everything besides Motul 660 fluid and the SS track air config
Maybe the heavier 1le size wheels and tires are harder on these smaller SS brakes I’ll def give a setup like that a try tho before I upgrade to something bigger |
11-12-2020, 09:13 AM | #7 | |
If you are getting into that, then yeah a bigger set of brakes would be the next best step to take.
2017 SS 1LE.
11-12-2020, 09:15 AM | #8 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
What do you mean by getting them hot? Long pedal? Pad fade? Smoking wheels? Just curious. PS No idea what pad an SS comes with (vs SS 1LE). My stock brakes take whatever i throw at them. Cheers! |
11-12-2020, 09:18 AM | #9 | |
j1ss
Thank you! Lap 4 they smelt like they were starting to burn up and there was blue/gray smoke behind me but I was thinking maybe its just because the brakes have never got that hot before, bc on the 2nd run it didnt happen Pedal never got long but I kept the stints really short Regular SS comes with some 4 pistons that look like theyre more brembo licensing than actual brembos, and not sure on the pads. I want the 6 piston brake upgrade so bad lol. - it def stops, but the heat management would be much better with bigger rotors like a 1le |
11-12-2020, 09:31 AM | #10 | |
Agree, cant go wrong with a six pot set up. Cheers! |
11-12-2020, 09:45 AM | #11 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
Also agree that you can't go wrong upgrading to 6-piston setup. I'd search for a used set before buying the GM kit or the ZZP kit. You might even find a good deal on ZL1 brakes. |
11-12-2020, 10:04 AM | #12 | |
j1ss
11-12-2020, 10:05 AM | #13 |
j1ss
These are stock brakes so the dealer would have bedded them if they did or didnt I dont know, but they've never gotten as hot on the street as they did on the track I was thinking that could have been it but I have no clue haha
11-12-2020, 12:27 PM | #14 |
