Old 02-06-2020, 12:39 AM   #99
lcd550
lcd550's Avatar
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert
Originally Posted by Chutzpah View Post
Can I ask, do you drive with the top up and the windows down? I typically don’t, if the tops not down, then the weatherman made a mistake.
With glass delaminating on multiple verts, multiple times, makes me wonder if that’s the cause. You should be able to drive top up, windows down and not lose rear glass. What a PIA.
Good luck..
I don't drive with the top up/windows down. I'm in SoCal and my Camaro is a daily driver...I try and drive with the top down every chance I get.
lcd550 is offline   Reply With Quote
Old 02-06-2020, 05:36 AM   #100
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
That answers that then, must simply be bad adhesive. Thanks
Old 02-06-2020, 05:58 AM   #101
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
...or design putting excessive tensile peel-stress on the adhesive/glass interface. <5 years is premature for a vert top to fail. That said, convertible and fabric/vinyl vert tops never last forever ... ~5-10 years is normal for top longevity (5 if kept outside, 10 if garaged).
My local top guy replaces Camaro tops for the local dealers (both their warranty and non-warranty work). When I had my wife's '07 in for a new top a couple years ago I stopped by with the Z. He had just replaced a top on a '18 RS the dealer had on the lot ... one of Cox's PDI techs had put something on it that dissolved the adhesive (turned it white).
$#!t happens... sooner or later, but it happens.
Old 02-09-2020, 12:05 PM   #102
VJChevelle67
The Beast
VJChevelle67's Avatar
Drives: 2016 2SS Camaro Convertible
Top down
Drive with top down always or top up only in the city slow driving with windows down less air pressure
VJChevelle67 is offline   Reply With Quote
Old 02-09-2020, 08:04 PM   #103
Algeron
Algeron's Avatar
Drives: 2023 ZL1 Convertible, 1998 Z28
I have a 2016, and having the same issue. I will be checking with the dealer tomorrow to see if this is covered as part of the extended warranty.
2023 Rapid Blue ZL1 Convertible
Algeron is offline   Reply With Quote
Old 02-16-2020, 11:00 AM   #104
VJChevelle67
The Beast
Warranty
I sure hope it’s covered for you and for others with that problem
Old 02-22-2020, 08:22 PM   #105
nitrojedi
Drives: 2018 Camaro SS Convertible
Originally Posted by the chosen one View Post
UPDATE: Dealer had another convertible top shop replace the rear window. The new glass and the area around it looks as good as new.
So they were able to keep the top in place and just repair/replace the window ? if so that is awesome.
nitrojedi is offline   Reply With Quote
Old 04-19-2020, 12:35 PM   #106
slvr162ss
Drives: 2016 2SS Convertible
Anyone Had This Issue Covered by CPO Warranty?
My window has started to separate from the top. Brought it to a Chevrolet dealer with a copy of the TSB in hand. Was told by the dealer and Chevrolet Customer Assistance Center that the Chevy Certified Pre-Owned bumper-to-bumper warranty doesn't cover the window separation problem. Their reason is that the folding top is a trim piece and the warranty excludes trim items.
slvr162ss is offline   Reply With Quote
Old 06-02-2020, 11:52 PM   #107
YaasQwn
Drives: Chevy Camaro
I have had my top replaced twice in the short time of ownership (18 months) last time I had it replaced Dec 23rd 2019 I just noticed its delaminating/detaching again. I am now out of bumper to bumper warranty. But the technician told me the new top had a 1 year warranty so tomorrow I will find out if that is true.
YaasQwn is offline   Reply With Quote
Old 06-05-2020, 09:51 AM   #108
Algeron
Algeron's Avatar
In my case, the dealer had to replace the entire top. Luckily, it did count as a warranty repair.
Old 06-20-2020, 07:56 PM   #109
slvr162ss
Hi. You mentioned "extended warranty." Is that a certified pre-owned or a GM extended protection plan GMEPP? Curious because the GMEPP specifically excludes "convertible tops, any convertible top assemblies."
Old 09-29-2020, 10:28 AM   #110
Ivar
Drives: 2019 2SS Convertible
I had same issue, I went to dealership about a week ago and they said they will be ordering a brand new top, covered by warranty.
Ivar is offline   Reply With Quote
Old 09-29-2020, 07:18 PM   #111
Warsteiner
Warsteiner's Avatar
Drives: 2016 Red Hot 2LT RS Vert
I purchased some 3M top glue, 3M primer, and suction cup clamps and am going to attempt my own repair for mine. Mine is just in one corner and I have read on other forums (this is a common issue for all convertibles) that this can work. I figure what have I got to lose? If this works I save $1400 (the supplies cost me about $100).
I will let you guys know how it goes once it is done.
Warsteiner is offline   Reply With Quote
Old 09-29-2020, 11:30 PM   #112
lcd550
lcd550's Avatar
Good Luck & keep us posted!
