Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-05-2020, 08:25 PM   #1
unssafe
unssafe's Avatar
Drives: 94 impala ss 396 6spd
1st Dyno tune
Hello
I just had the supercharger replacement done under warranty (13 ZL1 w/ 40000 miles) then I added I. D. 1050x injecters and a SW tuning e85 kit. Took It to get dyno tuned today, I was hoping for more hp, it started at (car already had Cai, bigger tb, full length headers and 3 inch cat back) 505 then to 522 I think. Then added about 12 gallons of e85 to about 4 gallons premium already in the tank. It worked its way up 554 hp and we stopped. I plan now to add a bap and smaller supercharger pulley, most likely a 2.44. I am planning on going to the Cadillac track attack on Feb 22 and getting those items and having it Dyno tuned again and then I will stop with adding hp for awhile.
Here are the Dyno sheets, both are same final pull just one sae and the other standard.
dave
13 ZL1
12w7 plus a few other things
unssafe is offline   Reply With Quote
Old 02-05-2020, 08:49 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Do the lower pulley before the upper.
Vegas Bound is offline   Reply With Quote
Old 02-06-2020, 12:18 AM   #3
Coop[580
Coop[580's Avatar
Drives: 2012 ZL1 Ashen Grey
is that your car in the pic? Looks like a 6th gen front end.....
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam
Tuned and built by Speed Inc
635/632-93 octane
725/738-E85
Coop[580 is offline   Reply With Quote
Old 02-06-2020, 11:04 AM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
100% correct.
ATI super damper, with a 10%.
You will need more than a BAP to support 20% overdrive pulley combo.
Monitor fuel pressure, Stock pump with BAP runs out at 700 RWHP on Gasoline and the more E you put in the lower that number goes.
With E-40 I would expect you to run out of fuel pump at 595 RWHP, which you can easily do with a 10% pulley.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-06-2020, 06:13 PM   #5
unssafe
unssafe's Avatar
Thanks for the info on the different pulleys. I will definitely look into more before I do anything. The thinking behind the supercharger pulley is it may have the old style isolater and will need to be replaced. I figured that would be the easiest to do.
My car is a 5th Gen with a 6th Gen bumper cover.
dave
13 ZL1
Old 02-07-2020, 07:05 AM   #6
JANNETTYRACING
If it is not noisey don't worry about it.
And don't void the supercharger 10 year 100K warranty by changing the upper pulley and or isolator.
Run it until it is noisy then have the whole supercharger replaced
Old 02-07-2020, 10:50 PM   #7
Coop[580
Coop[580's Avatar
Sorry off subject but can i see a pic of your car with that bumper
2012 M6
635/632-93 octane
725/738-E85
Old 02-09-2020, 08:58 PM   #8
diddies
Drives: 2013 ZL1
Originally Posted by JANNETTYRACING View Post
100% correct.
Ted.
If I was going to place a 28% overdrive pulley, the BAP wouldn't work? My car will be going in the shop in about a month and I currently have CAI, Kooks Headers, and ported TB. I am adding a BTR Stage 2 cam, e-85, and was planning on a 28% overdrive pulley. Can I not do this with just the JMS BAP? If not then what would you recommend?
diddies is offline   Reply With Quote
Old 02-10-2020, 06:49 AM   #9
JANNETTYRACING
Absolutley not.
Even on straight gasoline you would not have enough fuel pump with a JMS BAP.
You will need a Fore innovations return twin pump fuel system and ID1300x injectors.
Give us a call we will spec everything out for you and get you what you need.
Ted.
Old 02-10-2020, 08:07 AM   #10
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Ted: What do you like about the Fore system over a similar Squash system?
JB'sZL1 is offline   Reply With Quote
Old 02-10-2020, 08:42 AM   #11
JANNETTYRACING
Experience, fuel delivery, customer service.
Old 02-10-2020, 06:18 PM   #12
Dega Man
Drives: ZL1
It does appear to be a 6th Gen front cap with the 5th Gen hood.
Dega Man is offline   Reply With Quote
Old 02-10-2020, 09:49 PM   #13
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I think it's probably the Ikon front bumper conversion. There's a guy on youtube that has a nice example of a ZL1 that has been given the 6th gen treatment: "Outlaw Performance Garage". Here's a pic of his car
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
