02-01-2020, 08:50 PM | #1 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Throttle body
I might pick up a 102mm throttle body but i'm not really willing to pay $400plus for one. There's a blackhorse racing one for under $200 new, an a-team for under $200 new and a BBK used for $240. Anyone used any of these? I know the throttle bodies can be finicky. The bbk looks like it uses the stock electronics and motor, the others come with everything.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
02-01-2020, 09:48 PM | #2 |
Started#gottalovethatblue
BBK had a bad streak of throttle bodies having throttle plates sticking. Not sure if/when this ever got fixed.
02-02-2020, 06:41 AM | #3 |
Hmmm. Maybe worth just buying the blackhorse one on amazon and seeing how it works for $160. If it's a pos i can always return with amazon lol.
02-02-2020, 07:38 AM | #4 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
I tried to BBK 102 tb and it caused my engine to pulsate at speed. But I did not tune the car because they told me it did not need to be tuned to use it. So I returned it. Also this was on my NA 13' 1le.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
02-02-2020, 07:40 AM | #5 |
Was that after you had the forced induction? I wasn't gonna change the throttle body but talked to Ted Jannetty at length saturday and at my power level they are good for about 15hp gain i guess.
02-02-2020, 08:34 AM | #6 | |
02-04-2020, 10:51 AM | #7 | |
The larger the blade the more it flutters at WOT which will put it in to Reduced power mode, this is a big problem with aftermarket throttle bodies. If you can't swing a good one don't do one. Ted.
www.jannettyracing.com
02-04-2020, 10:57 AM | #8 | |
02-10-2020, 11:09 AM | #9 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
Green, I have one for sale if you need one. Nick Williams 102 boosted TB. PM me if you are interested.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
02-10-2020, 11:52 AM | #10 |
Yea man, I saw it I'm not willing to pay the NW pricing. But thanks!
02-10-2020, 12:45 PM | #11 | |
Ted.
02-10-2020, 01:18 PM | #12 |
Yea I'm not gonna buy a cheap one either I am just going to go without. $ per/HP not worth it to me at this point.
02-10-2020, 08:32 PM | #13 |
Drives: 2010 SS L99 Join Date: Sep 2018
I'm going with a NW 102mm. Remember the GPI intake manifold shootout and how much the combo picked up on the Hi-Ram going from the stock TB to the 102mm...the LOD intake was never tested with a stock TB, so it begs the question of how the 102mm would help to the wheels with the proper intake, both NA and boosted. As always, I will post my results when the time comes
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
02-10-2020, 08:58 PM | #14 |
Ted told me it's about 15hp with my setup. He's always been pretty spot on.
