Old 04-03-2018, 08:29 PM   #1
silkrckt
silkrckt's Avatar
Drives: 2017 Garnet Red 1LE
Quick Jack 5000 on 6Gen
Has anyone used the quick jack 5000 on their gen 6 Camaro? I used it on my gen 5 without a hitch. I am having trouble lining up the jack points with the jack. I suppose i need to get the jack pads to make it usable? any thoughts?
New Camaro --- 2017 SS 1LE Garnet Red -stock
Last Camaro --- 2014 2SS || 6 speed || NPP || Kooks 1 7/8 LT +Cats || Apex Catch Can || BW PTB || CAI induction || 12.99 @ 111 stock tires, 2.1 60'
Old Camaro --- 94 Z28 Vert-- Miss it.
silkrckt is offline   Reply With Quote
Old 04-03-2018, 08:51 PM   #2
Jsreo
Drives: 2017 2SS Manual
What model do you have? If the regular 5000 BLX and you use it with the existing lift points the car will be way to nose heavy and very unsafe - do not do this!
There are a few options, you can get these extenders (I would verify that they will solve the problem by doing a few measurements first though)
Or you can buy the 5000 EXT frame assemblies
Or you can do what I did and use a dremmel to cut new notches in the underbody. The pinch points extend all the way under the doors & you can lift safely using the new point and the original ones closer to the front wheel. The notches are not visible unless you are under the car
The extenders were not available at the time or I would probably have went that route before cutting the new notches
Jsreo is offline   Reply With Quote
Old 04-03-2018, 09:20 PM   #3
silkrckt
silkrckt's Avatar
Thanks for the info. I don't think the 6 total inches will allow it reach the jack points. I didn't know that the pinch points extend. This will help, I may make the small notches you mentioned if it comes to that. I did just purchase the ZL1 add-ons jack pads as well.
Old 04-03-2018, 09:30 PM   #4
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
I have a 7000 ext, no issue reaching the lift points. The standard length models would be too short. My understanding is the extensions bars make the standard model as long as an ext so it should work
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
Old 04-03-2018, 09:35 PM   #5
KS1LE
KS1LE's Avatar
Drives: 17 SS 1LE, 02 GTP
I use mine and have no problems. I use the notches under the door, not the front ones by the wheel.
2017 Mosaic Black Metallic 1LE
KS1LE is offline   Reply With Quote
Old 04-03-2018, 09:55 PM   #6
silkrckt
silkrckt's Avatar
I re-positioned the quick jack, the wheeled end toward the back tires. It lines up with the pinch weld cut outs you mentioned. I ordered the jack pads to make things easier.
How is the stability. It was mentioned that it would be unstable at these points.
Old 04-03-2018, 10:32 PM   #7
KS1LE
KS1LE's Avatar
I have no problems with it like this.
Old 04-04-2018, 05:25 AM   #8
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Received the 5000 SLX for Christmas and it's too short to reach the factory recommended lift points. Ordered the extensions on 1/8/18 and I only received 1 (should be a pair) about 2 weeks ago. Since then they have removed them from their website and I received a $70 credit for all the BS they are putting me thru. Still waiting on the second extension.
I have the ZL1 add-on lift points and the QuickJack pinch weld blocks. With everything I have I hope to be at a comfortable place to lift the car once the other extension arrives.
Glad to see it being used on the 6 Gen!
Gabhart is offline   Reply With Quote
Old 04-04-2018, 08:37 AM   #9
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Which model do you have?
WhiteNight is offline   Reply With Quote
Old 04-04-2018, 09:29 AM   #10
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2017 ILE SS
I really want one of these but..... I'm still trying to decide between one of these lifts or a Springfield Armory M1A. I just can't decide.
Bad Anvil Garage is offline   Reply With Quote
Old 04-04-2018, 09:36 AM   #11
modru2004
Drives: 2018 2ss
which will you use more? if it were me it would be the m1a.
modru2004 is offline   Reply With Quote
Old 04-04-2018, 09:46 AM   #12
Bad Anvil Garage
I'd probably use the lift more but I already have a low profile jack and jack stands...
Old 04-04-2018, 09:51 AM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Well! There's your answer...put the jack and stands on craigslist to earn a deposit towards the M1A!
Old 04-04-2018, 09:28 PM   #14
KS1LE
KS1LE's Avatar
The 5000 SLX
