08-07-2018, 05:39 PM | #1 |
Drives: 2017 ZL1 Join Date: Jan 2018
Anyone added extra mufflers after their longtube header install?
I'm considering adding 2 resonators where the stock cats were, and also a Magnaflow "2 into 2" dual inlet/ outlet muffler in the rear, just before the rear differential. I had done this with my SS sedan and it's the only way in hell to make things civil when using longtubes, even with the stock NPP system.
08-08-2018, 11:50 AM | #2 |
Drives: 2023 2SS Convertible Join Date: May 2009
I would listen to it first - these cars have a much better stock muffler than the 5th gens.
-Geoff
08-08-2018, 12:55 PM | #3 |
Drives: Garnet Red 2018 SS 1LE "Deadpool" Join Date: May 2018
I kept my stock mufflers when I did my off-road headers and midpipe. NPP compatible mufflers are retarded expensive, and it just wasn't worth it to me. When I need it quiet, I drive it in Stealth mode and it's right between the touring and track mode sound...not to quiet, but not obnoxiously loud either.
08-11-2018, 12:07 PM | #4 |
your not going to have room. i asked my muffler shop about putting resonaters in with my headers and cat back. no room.
08-12-2018, 06:08 AM | #5 |
Borla lists a resonator section that is designed to be used with their X-pipe. It would go in place of some of the piping in other words. But I've seen no reviews of how well it works.
08-12-2018, 02:27 PM | #6 | |
@maplefed
Drives: 16' MBM 2SS, Join Date: Sep 2016
The middle resonator combined with the S Type is what composes their touring system.
@maplefed
08-12-2018, 04:04 PM | #7 | |
And two resonators will go in place of the downstream catalytic converters: |
