dave@hennessey
Old 12-24-2014, 03:44 PM   #1
fire13man
fire13man's Avatar
Drives: 2014 Camaro 2SS in Blue Ray Metalic
Need an Electrical Consultation
Hoping one from the Camaro Experts on here can help me with this. I'm looking for a 12vdc wire I can tap into that is controlled by the light sensor on the dash? All I keep finding are wires with just under 5vdc, I need 12vdc. Does what I'm looking for exist inside the car and if so, where is it??
Thanks.....
fire13man is offline   Reply With Quote
Old 12-24-2014, 03:51 PM   #2
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
you could always tap into the headlights, since they turn on by the sensor? I imagine you are trying to wire lights up to come on when it get darker out?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 12-24-2014, 04:37 PM   #3
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
Are you looking for just 12v, or are you looking for lights that dim at night?
gutterball is offline   Reply With Quote
Old 12-24-2014, 06:02 PM   #4
fire13man
fire13man's Avatar
I installed the Diode Dynamics LED Cup Holder inserts in my SS, they run off 12VDC. I would love to hook them up so they come on at the same time the ABL lights do. I know the ABL light are controlled by the light sensor. Being able to dim them isn't all that important to me.
http://www.diodedynamics.com/store/a...holder-inserts
Old 12-24-2014, 06:36 PM   #5
Tricksta
Tricksta's Avatar
Originally Posted by Comrando View Post
LEDs all use 5VDC. The kit probably uses a Zener diode to restrict the 12VDC to 5VDC.
You should be fine connecting to your ABLs.
Light sensor doesn't have 12VDC from what I see in wiring diagrams. but if you need 12VDC you could like I said tap into the headlights, or interior Dash/Center Console Lights, These will turn on if you manually have lights on or also if set to auto they will come on when the light sensor tells the interior lights to kick on.
Modifications
Old 12-24-2014, 09:58 PM   #6
gutterball
gutterball's Avatar
First of all LED'S work on current not Voltage, you want approx 40ma going through the led's . If you bought this kit for the car, then it probably has a res. to limit the current and is made for 12V. You can get the 12V from the 12V Pwr connector in the Arm Rest
Old 12-24-2014, 10:44 PM   #7
Tricksta
Tricksta's Avatar
Except that is not what he wants. He wants them to turn on when light sensor tells lights to turn on.
Modifications
Old 12-24-2014, 11:03 PM   #8
Mean Green Z28
Drives: 2010 2SS
no, he wants them to dim and work just like the abl lights on the door. they only come on somewhere halfway through the range and get brighter
Typing fat fingered on my GS3...excuse any sfelling mitcakes
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 12-25-2014, 08:04 AM   #9
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
The OP only wants the LEDs on when the ABL is on. The power in the console is on whenever accessory power is on.
A resistor does not limit current. A resistor in-line with a load divides the voltage proportionally between the resistor and the load.
For example the LED has 125 ohms resistance. The maximum supplied voltage is 16V. We limit the LED to 4.5V.
16/4.5 = 3.56
We need a resistor 3.56 times the LED resistance.
3.56 X 125 = 445
You would use a 445 ohm resistor. The voltage loss across the resistor would be 11.5V and the voltage across the LED would be 4.5V.
If the kit uses resistors to lower the voltage and you want to power them from the 5VDC your ABL uses you will have to bypass the resistors.
Too much wrong information here I don't even know where to begin.
Different color leds are different voltages. A resistor must always be used in series with leds TO LIMIT THE CURRENT.
The formula for figuring out the resistor is as follows:
R=supply voltage -Led voltage/LED current
If the resistor is not a standard value always choose the next bigger size.
Rainbow1616 is offline   Reply With Quote
Old 12-25-2014, 12:40 PM   #10
gutterball
gutterball's Avatar
Tnx Rainbow, To put it simply, a resistor is added to limit current
Volt source 12/15V - LED volt. (2-3V) = 10-12V, div by led current (30-40ma)
=resistor value (approx 300 ohms)
Old 12-25-2014, 03:54 PM   #11
tomlink
tomlink's Avatar
Drives: 2011 Camaro 2LT RS
Send a message via Skype™ to tomlink
Sorry Comrando, I'm with Gutterball and Rainbow.
As far as the question about where to tap a source, I connected my cupholder lighting to the traction control wires. As I recall there are three wires into that switch, and one is ground and another for the switch backlight, which is on the same circuit as the ABL. Check the "lighting and cosmetics" section here on Camaro5 and you should get details.
tomlink is offline   Reply With Quote
Old 12-26-2014, 11:01 PM   #12
RedRaven
RedRaven's Avatar
Drives: 2012 2SS M6 CRT
Series resistance divides the current over the total resistance of the loop. An LED is about 100 ohms at 2 volts (it takes less than 2 vdc to bias, or "turn on" an LED). Therefore, if you have a 300 ohm resistor in series with the LED, the LED will draw about 1/4 of the total current available, given the voltage drop across the 300 ohm doesn't go below bias voltage.
That being said, looking at the manufacturer's page, the kit is 12 volt powered, so unless there is a built in voltage based dimming circuit, they will be the same intensity at all times. The Body Control Module controls the dimmer circuit, and may be 5 or 12 volt. Dimming could be accomplished by voltage regulation or by Pulse Width Modulation. If it's PWM the kits may dim.
2012 2SS M6 CRT
SOLD! - - 1983 Berlinetta, 305HO, Comp 235 cam, shorties
First real car: 1968 Malibu, '67 283, Canary yellow
RedRaven is offline   Reply With Quote
Old 12-26-2014, 11:43 PM   #13
turboguy327
Drives: 2011 Chevy Camaro
If you HAVE to make life hard and hook up to the sensor and HAVE to use 12v. Use a relay triggered by the 5v off the light sensor. There are easier ways but if you want to make your life harder use a relay.
turboguy327 is offline   Reply With Quote
Old 12-26-2014, 11:51 PM   #14
Mean Green Z28
Drives: 2010 2SS
V = I x R
or get an Arduino and write your own program to control lighting
