04-05-2019, 04:17 PM | #1 |
Drives: around in circles few days a month Join Date: Mar 2019
What to keep an eye on
Hey guys, I'll apologize if there's a thread somewhere but I can't find it. Please provide the link after write something funny at my expense
I'm interested in known problems with the LT4 or the ZL1 1LEs. On other forums there's whole threads devoted to people posting up all kinds of blown up Subaru motors. I had to install a new tranny in my Dodge if I wanted to tune my Cummins 6.7L for any kinda power as the 68re is known to be junk. I don't see that here. Is there a good place to find a list of things I should watch for? Are Camaros bomber? How's GM as far as honoring their warranty? I figure I'll check for leaks and keep good rubber on the rims and I should be good for any track day. |
04-05-2019, 04:32 PM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
Crickets...
04-05-2019, 05:57 PM | #3 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Dont know if there are any real gotchas that are wide spread, for street use. There were some threads on here about some 2018 (august thru october) late build cars having oil pump failures. The stock tires only seem to last approximately 10K miles. If you dont drive your often, batteries will just die unless kept on a tender.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
04-05-2019, 06:48 PM | #4 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Aside from the oil pump failures there are some TSBs for wiring in a couple places in the engine compartment that can rub through. Honestly, the LT4 has proven to be a really reliable engine. You’ll see a few posts about problems, but nothing widespread in any one area.
04-05-2019, 07:55 PM | #5 |
Thank you Al Oppenheiser!
The factor of safety on the LT4 internals is at least 75% probably closer to 100% ... many folks routinely take their cars to 1000hp+ without issue. It's a total monster.
The three ZL1 wiring TSB's are attached (2 can be done without lifting the car and are easy to do yourself). All can/will be fixed on GM's dime while the car is under original 3/36 warranty. |
04-06-2019, 12:09 AM | #6 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
The only thing you'll need to keep your eye on is the speedometer and the gas gauge.
04-06-2019, 12:18 AM | #7 |
Drives: 2018 ZL1 A10 Join Date: Feb 2019
Tires . . . TIRES ! ! ! . . . Happy Meter will wear your tires FAST
04-06-2019, 10:01 AM | #8 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
04-06-2019, 10:26 AM | #9 |
Thank you for all the replies gentlemen. That’s a relief coming from a Subaru and Dodge.
04-06-2019, 12:05 PM | #10 |
The Black Emerald
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS Join Date: Sep 2011
My cam split at just under 13k, replaced under warranty. First one with an engine problem from the 17’s I believe lmao.
04-06-2019, 12:19 PM | #11 | |
04-06-2019, 12:30 PM | #12 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Holy cow the A10 loves the gas compared to the M6.
ZL1::J-E-T-S JETS JETS JETS |
04-06-2019, 12:31 PM | #13 |
Drives: 2015 ZL1 Join Date: Jan 2019
04-06-2019, 02:16 PM | #14 |
