Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 01-08-2016, 11:20 AM   #1
130R
Drives: SS
PCM X1 Pins 19 & 43
Anyone know what Pins 19 and 43 are for? Both are designated as 'Ignition Voltage'. Can either (or both) of these be used as a 12V switched source?
130R is offline   Reply With Quote
Old 01-10-2016, 12:06 AM   #2
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
There's an ignition fuse in the underhood fuse block, fuse #15 i believe. I'd grab an add-a-fuse from an autozone and tap that if you need an underhood 12v source rather than splice your PCM's harness.
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
