02-13-2021, 12:22 PM | #1 |
Drives: '15 Z/28 Join Date: Jun 2016
Bolt In Sparco Race Seat Bracket - Plug and Play
I also have something else someone might have an interest in...
I have a seat bracket set up that lowers a race seat to it's lowest point and still allows for slider adjustment. It's the same set up as AustexaSS has and was so helpful with when I needed a solution. Here is his thread: https://www.camaro5.com/forums/showt...highlight=seat It's a Gen5 slider that has been carefully cut and welded with sparco race brackets. I have all the harnesses and plugs to simply plug and go. No messing with finding and ordering stuff. I used a Sparco race seat and do not know whether the brackets would work with other manufactures such as Recaro or not. Switching out the OEM Recaro for the Sparco race seat took literally about 5 minutes minutes. I am 6'2" with an extremely long torso and this allowed me the clearance without issue for my helmet. If one removed the seat bottom pads you can gain even more headroom. $200 plus shipping. |
02-14-2021, 06:22 AM | #2 |
Drives: 14' Red Z/28 #336 Join Date: Mar 2016
can you post some pictures of yours or send me a PM? Possibly interested
02-14-2021, 11:55 AM | #3 |
02-15-2021, 11:01 AM | #4 |
Drives: Z/28 15 AGM Join Date: Sep 2015
Which Sparco side mounts are included? The sparco side mounts in the images in Austexass' thread look like the QRT. Thanks for the info.
02-16-2021, 11:36 AM | #5 | |
https://www.sparcousa.com/product/side-mount-steel |
