02-04-2021, 10:03 PM | #1 |
Drives: 2015 Chevrolet Camaro 1Ss Join Date: Oct 2020
3.45 Or 3.91 Differential
Any Legit Pages Or Places I Can Get A 3.45 Diff Or 3.91 Diff
02-04-2021, 10:16 PM | #2 |
Or anyone that can help me out finding one
02-04-2021, 10:25 PM | #3 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
Far away, but worth considering:
https://www.camaro5.com/forums/showthread.php?t=587440. Otherwise, you’ll see those diffs crop up her for $400-$900. You can try the salvage yards but that’s a mixed bag. |
02-05-2021, 01:34 PM | #4 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I seen two 1LE diffs, of course 3:91 gears, on ebay. One had 67,xxx miles and it was $1395.00. The other had just over 40,000 miles and listed at $1699.00. The unit listed by Pearl is a steal considering what you get with the 1LE cradle.
02-05-2021, 01:51 PM | #5 |
Drives: 15 Camaro SS Join Date: Oct 2018
For fure
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
02-05-2021, 01:55 PM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
That is a good deal on that cradle considering the upgraded shafts, shocks and hubs on the 1LE. Plus you get a 28mm rear bar if that works for you. It's an even better deal for an early SS that has not upgraded to FE4.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
