12-30-2020, 08:37 AM | #1 |
Need help with Tire choice.
I'm done with the stock Goodyear's. They never seem to heat up enough with moderate driving and very hard to keep the rear from letting loose with hard acceleration. I currently have 750 wheel and I don't drag race but I do like to roll race once in a while. Also looking for something I can drive in cooler and or rainy weather.
12-30-2020, 09:07 AM | #2 | |
'20 ZL1 1LE A10,
12-30-2020, 09:13 AM | #3 |
Drives: 2017 ZL1 Join Date: Jan 2017
PS4S is your best option. I am running them right now and have no regrets coming from stock GYSC3.
They don't like the extra 200+ whp I've got with my current setup in 1st and 2nd but there is not silver bullet tire that would without being 100 or less tread wear, warm and in proper conditions. The PS4S aren't bricks when cold and will gain traction as they warm up to nearly GYSC3 levels. They PS4S also have no issues wet unlike the GYSC3 (very slippery in rain) This is the best suggestion I have if you want to operate in cooler/wet weather. You will likely get the same response over and over again, there is no better compromise tire out there currently.
12-30-2020, 09:32 AM | #4 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Wow, you guys are having luck with them? I have them now and spin at any speed. I am near Tampa where we still have warm days (70s) and I still spin. Now looking into a Drag Radial. I know at regular psi DRs will still spin from a stop, but i hoping to gain traction from a roll.
Of course it is very tough to decide on a DR as well if you go that route. I have had a bunch of people swear by the Nitto 555r and then another group say they are not as good as the Mickey Thompson ET Street R tire. Guess i will have to go 17x10.5" rears and thinking 18x8" fronts
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
12-30-2020, 09:38 AM | #5 |
Oh they spin for me but they are the only tire you could consider operating on this car when the OP mentions cold and wet.
I'm heading for 345/30R19 NT555RII in the rear this coming year along with TBD in the front
12-30-2020, 09:46 AM | #6 | |
Drives: '18 ZL1 1LE Join Date: May 2020
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
12-30-2020, 09:49 AM | #7 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Yokohama Advan Apex have been good for me @ 670WHP
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
12-30-2020, 09:51 AM | #8 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
i dont think there is a tire made that wont break loose cold wet or any combo thereof with a 600+HP car sorry. for driving in the rain and cold temps the best bet is the PS4S as will be the consensus among the internet. Do mine break loose, sure do when cold but like i said all tires will
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
12-30-2020, 10:26 AM | #9 |
I usually drive in Manual mode, and if I'm above 30 mph in 3rd and floor it, the 4S usually do not spin on warm dry payment
'20 ZL1 1LE A10,
12-30-2020, 10:40 AM | #10 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Went PS4S on my new ZLE. I believe they were 1-2lbs lighter than the SC3, and have a longer tread life (on paper at least) while still being a high performance tire. My only regret is not having a Goodyear that is “closer” to OEM.
12-30-2020, 10:54 AM | #11 |
I would try the 555r2...it's classified as a Drag radial but it is a much improved tire all around that still provides great traction. I don't think you can do better for a high horsepower street car. It has much improved wet traction due to the 2 large channels added in the tread pattern and a stiffer sidewall for better high speed stabillity. Now that doesn't mean you go out and drive spirited in a rain storm either but they will do fine if you leave the nannies on and drive normal in the event you are caught in the rain.
2016 NFG 1SS A8
12-30-2020, 10:55 AM | #12 |
Drives: On Hiatus Join Date: Apr 2020
Any truth to PS4s running narrow for its size?
12-30-2020, 10:58 AM | #13 |
12-30-2020, 10:59 AM | #14 |
i had the ps4s on my car i took them off and replaced them with goodyear supercar3 better on track performance and i dont drive my car on streets much anymore
