12-07-2020, 03:02 PM | #1 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
First mod-parts arrived today.
Now I just have to wait like 5 months to try em out.
12-07-2020, 03:50 PM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
Nice! Mine should be arriving on Thursday!
12-07-2020, 04:22 PM | #3 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Very nice
And in other news, it’s 80f today. |
12-07-2020, 06:43 PM | #4 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Send em my way i got all winter to test em out down in FL.
12-07-2020, 07:35 PM | #5 |
Let me know what ya think when you get it on. I know it’s not going to be as dramatic a difference on the A10 as the M6 seems to, but we all spend way more time at 10-30% throttle than 50-100% which is where this TB shines according to their posted flow charts.
Rub it in why don’t ya. I bet you would! Last edited by gtfoxy; 12-07-2020 at 07:46 PM. |
12-07-2020, 07:57 PM | #6 |
12-07-2020, 09:24 PM | #7 |
Drives: 2016 SS 2SS Join Date: Dec 2016
I have both Tb and controller ... its a sweet combo you will love.
12-07-2020, 10:20 PM | #8 |
12-07-2020, 10:29 PM | #9 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
OP- Did you trade in your OEM TB or did you just buy it and keep the OEM TB? Just wondering because I’ll be upgrading soon myself.
12-08-2020, 09:59 AM | #10 |
12-08-2020, 02:15 PM | #11 | |
Does it seem to matter what drive mode you are in? Sport/Track etc? |
12-08-2020, 02:25 PM | #12 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Unfortunately, I didn't noticed much after I switched from my Pray ported 87mm TB to a Soler 95mm. I couldn't detect any increase in airmass which I thought I would, but I should have taken more logs. It was in fact slightly higher but I needed more data to conclusively prove. I was hoping it would change the jerky feel, but I will say it helped with the rolling reverse to drive RPM drop where it almost kills the engine. After I put my cam in there were situations where you could rev up in reverse then switch to drive, usually under load or up a incline, and once the engine loaded the driveline again RPMs would fall and the engine would almost die. With the increased airflow at lower throttle positions with the Soler I think it has fixed that issue and the engine is now able to get the increased airflow, and subsequent increase in torque, it needs to keep the engine from dying. I tried a bunch of different idle tuning stuff in HP Tuners to try to fix it, but HP Tuners just dosen't have the tables we need or they either don't work.
12-08-2020, 06:13 PM | #13 |
I did notice the TB helped with my screwed up C7 as lag was not as bad and i could hear more pops in the exhaust. Takes a few days and trips for things to get better.
12-08-2020, 07:14 PM | #14 | |
No track day yet with the Soler TB/TC to see what works best there but with so many settings on the throttle controller finding exactly the throttle response required for the situation is a non issue. I've played with them all and you can really make the throttle response dance up to what i would call a hair trigger LOL I've found very few things in life can be individually tailored to taste like the Soler throttle controller.... And there is a distinct difference in every single setting... in every mode. The absolute best part is getting rid of the annoying disconnected feeling i had with the stock throttle pedal and the off idle take up which is exactly what i purchased this combo for and it works perfectly as advertised. This is the only modification i have done to my car other than a couple of small exterior details and as far as mods go i really feel like i got my moneys worth with the Soler products (not sponsored :-) Last edited by Racerman27410; 12-08-2020 at 11:25 PM. |
