12-01-2019, 10:07 PM | #1 |
Stigs Bahraini Cousin
Clutch return spring kit
So my clutch got stuck 1/2 under hard shifting on 5th gear. One of the guys told me that there wqs a tsb for this issue and the remedy is to swap out the clutch pedal ti a ZL1 or change the return spring.
I am looking it lingelfilter L360091410. It says it fits 10-13 caro ss, any idea if it works with 14-15? Are they the same?
2015 CAMARO 1LE
12-01-2019, 10:34 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Yes it does. I put one on earlier this year. Instructions are a little confusing but it works. I never had an issue beforehand but it returns it really well. Makes the pedal a little stiffer.
12-02-2019, 03:38 AM | #3 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
I fitted the Lingenfelter kit to mine (along with the hard braided clutch line) after experiencing the same at the local drag strip. My pedal used to stay down in mid-shift and smoke the clutch. Disappointingly it still happens now and again. I'm hoping a multi-plate clutch will help...
12-02-2019, 04:14 AM | #4 |
Tri-County Camaro SWFL
I've never had an issue switching into 5th due to the clutch stick issue. Mine has always been hard launching causing it to stick. I have had the LPE return spring on mine for probably near 5 years and it works.
12-02-2019, 04:53 AM | #5 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
And while you're down, throw away nonsensical torsion spring on the clutch pedal that some GM donkey invented Before I learned about the Camaro5 and some Lingelfilter kit, I thought of a similar return spring from a trunk old germany car, and a tire valve holder from a duality truck. The upgrade is not visible and works great. Otherwise, this adjustment is just one of the many I did to make my clutch work correctly even in extreme situations. |
12-02-2019, 05:29 AM | #6 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I've done everything one can do to upgrade the clutch and hydraulics. I use the return spring as well. I like the way it makes the pedal feel. Call me weird.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
