07-29-2019, 09:26 PM | #1 |
Stigs Bahraini Cousin
AC system pressure?
So where I live the ambient temperature is around 40-42 degree C. had a leak in my low pressure port valve and had it repaired already, the mechanic/technician charged my ac system and had it around 30 psi showing on the gauge but I am 100% sure I've seen it before at 40 psi when used to be cold though the mechanic says 40 is overcharged!!. It is not blowing as cold as it used to and I am guessing I am short on Freon.
Anyone has any idea of how much should a fully charged system pressure sit at for our cars?
2015 CAMARO 1LE
07-30-2019, 04:53 AM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Evac the system add refill for accuracy. 1.32lbs or .6kg r134. Add PAG oil if needed.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
07-30-2019, 07:11 AM | #3 | |
Low pressure side is used to recharge the system, how much should the system pressure be ? 0.6 is the freon capacity
2015 CAMARO 1LE
07-30-2019, 09:39 AM | #4 |
SomeguyK
You said in your original post you weren't sure if the system was properly charged or not. The pressures won't matter if the system isn't filled properly. Also, the ambient temperature will affect the pressures. In order to properly measure the running pressures, an AC manifold gauge set needs to be hooked up to the low and high side. Both sides need to be checked. I would rule out low refrigerant by doing an evac and recharge with the proper amount.
More to come. |
07-30-2019, 10:06 AM | #5 |
Drives: A Sneaky Fast Camaro Join Date: Jun 2019
These small systems are VERY sensitive to the amount of charge in the system. If you are trying to set it up using pressure as a guide there are ALOT of things to consider that makes a huge difference in how cold the system will be. TOO many for a inexperienced person trying to get it right.
I 1st of all would do as Black_SS10 suggests BUT it has to be weighed in or very carefully put in that have the proper amount and the system need to be COMPLETELY EMPTY. I had poor cooling performance in mine and the pressures looked good. I had to let refrigerant out of the system because someone over filled it. Another problem you may have is the EXSPANION valve. If its not working properly it will never be cold and its hard to diagnose on these cars. If the system is charged properly, the compressor is working properly and the pressures look good the expansion valve may be the trouble OR moisture in the system. The proper way to charge the system if it was open to atmosphere for more than a few hrs is to replace the desiccant bag then vacuum the system before charging. Doing it any other way will fail. Good Luck |
07-30-2019, 10:46 AM | #6 | |
07-30-2019, 05:20 PM | #7 | ||
2015 CAMARO 1LE
07-31-2019, 09:15 AM | #8 |
They need to vacuum more than a few minutes if the system has been apart or completely discharged for any length of time to get the moisture out. And then there is no reason to not put the new charge in by weight. Or the old way of adding freon slowly until the temperature no longer drops. Of course neither one of these methods trouble shoot other problems in the system.
07-31-2019, 10:17 AM | #9 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I miss the days of the sight glass on the dryer. There was a canister with a small glass window on top the size of a dime. If it was very low on freon only gas was in there and it was clear. If it was full then you saw clear also and hard to tell if it was very low or full because all liquid behind glass is clear. But if it was full it was working usually so you knew if it was full or empty. The good thing was, you simply added freon until bubbles stopped passing by the window. No gauges or hassles.
07-31-2019, 02:16 PM | #10 |
I like the orifice tube systems, these expansion valve systems are weak at best. The expansion valve is old old 80 year old tech in a 20 something car.............weak is all I can say. The only reason they could have for not using a orifice tube is to generate lots and lots of dealer service work. No way to swap it either unless you want to make custom parts, just not worth it. the system is also TINY. It has no reserves, if anything is a little off it won't be ice cold like the older systems. I had to tweak mine because it just wouldn't get cold enough on a 90 degree day. The amount of refrigerant I removed was very little, oz or so but instantly it was ice cold compared to just cool. When systems are this touchy most will not be setup properly.
I'll tell ya what really twists my brain cells on these cars is the poorly designed fuel systems. This direct injection is so far from what it should be its stupid. I really want to get away from it, Maintenance nightmare. All the dealers I called had different services and they were all 350-500 dollars. Recommended every 18-25k miles! GM you and the entire industry are a joke! My grandmother could come up with a better system AND SHES DEAD FOR 40 YEARS! |
07-31-2019, 07:27 PM | #11 | |
Drives: Never just fly under the radar Join Date: Jul 2015
Side note my friends a master mechanic helping me so he's not getting paid anymore for the extra work but GM is banking on parts!
Old Skool |
07-31-2019, 07:53 PM | #12 |
Maybe this will help you, exert from 2010 shop manual.
Can download the shop manual from Blake here post #105 https://www.camaro5.com/forums/showt...t=19184&page=8
Old Skool |
07-31-2019, 08:34 PM | #13 |
If the expansion valve is not working you would see high pressure on the high side and lower than normal pressure on the low side. If you look at the chart I posted above it should look very close to that info. Another test if you can at it on these Camaros is check the inlet and outlet temp on the evaporator. Both should be very cold and very close to same temp.
If the high side pressure is high and the low pressure side is too low AND the evap inlet is cold and the outlet warm most likey the expansion valve is stuck closed and needs replacement. I really hate expansion valve systems in cars, constant troubles. |
07-31-2019, 09:01 PM | #14 | |
Thanks for the advice!
Old Skool |
