09-22-2018, 07:26 AM | #15 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
09-22-2018, 09:06 AM | #16 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Agree
Was not trolling Just talking about trans I know all the tech differences between those 2 cars. 19ss A10 who drove 16ssA8 will come with the same conclusions about the trans A10 way better than A8 Lucky ss guys to have this A10 available.... Won’t comment till new 19ss will compare to old one. |
09-22-2018, 09:15 AM | #17 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Im not 100% on this but I heard the A10 in the ZL1 is different than the A10 in the 2019 SS. Something about the A10 in the SS being just a slightly modified version of the A8 and the ZL1's A10 was a whole different beast.
09-22-2018, 09:21 AM | #18 |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
The A10 in the 2019 ss is not the same as the zl1 A10. It is from the Chevy truck. Maybe it will be heavy duty.
09-22-2018, 09:29 AM | #19 | |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Agree, that was my first thought. All I want is a reliable GM auto trans. Seems the last good one they made was the 6 speed L60e. I wish I could trade my A8 for that trans. I don't yet trust the A10. You can bet it will not be the same as the A10 used in the Zl1. They usually upgrade the auto for these high powered engines. |
09-22-2018, 09:33 AM | #20 |
Drives: 2018 Camaro SS Join Date: Mar 2018
09-22-2018, 09:48 AM | #21 | |
Drives: 2017 Camaro Join Date: Mar 2018
The only way the 10 speed will be better is if the ratios in the useable acceleration range help. You still have to understand, even though the shifts are faster you still lose acceleration during a shift. I honestly don't think you'll see much of an improvement in 1/4 mile times between the two trans. |
09-22-2018, 09:54 AM | #22 |
Drives: 2019 F150 Join Date: Jul 2016
The extra gears may allow for a higher top speed and acceleration from 70mph+ could improve too. If you get tired of rowing through gears in traffic, A10's a good option
09-22-2018, 09:57 AM | #23 | |
Drives: 2017 Camaro SS coupe Join Date: Dec 2016
Plus there are just 6 gears to get to 1:1, 7 and 8 are overdrive. With the 10 speed it's 7 shifts to 1:1 with 3 overdrive gears. Since I paddle shift mostly I prefer my 8 speed - less shifting.
1SS, Recaro seats, A8 w/paddle shift extensions, NPP, Magnuson 2300 supercharger, Flowmaster American Thunder exhaust and x-pipe, factory handling kit, Phastek lowering springs, Alpine sound system w/JL sub, Lexani custom 21" wheels, Michelin Super Sport 4S tires, Bigwormgraphix striping, Chevy Performance Brembo big brake kit, darkened taillights and Remin carbon fiber dash kit.
09-22-2018, 10:05 AM | #24 |
Ok
If 19ss A10 is different from Zl1 A10 I’m out... May be the case, and sorry for you because ZA10 is a beast!!!! Back to the apples, If you disregards the cosmetics (hood, front grill, spoiler, recaro, tire size, red trim...) The 2016-17-18 ss with MRC and dual exhaust is almost the same gen6 as the Zl1 Only differences are: -surpercharger, -elsd -A10 vs A8 we are debating here... Now you can change and tune the ratio Then the 19ssA10 may be different from Zl1 A10 |
09-22-2018, 11:27 AM | #25 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
It’s a tough choice the unknown a10 or the a8 with the known shudder issue.
09-22-2018, 11:30 AM | #26 | |
2016 NFG 1SS A8
09-22-2018, 11:43 AM | #27 | |
I test drove an ‘18 GT A10 right before buying my ‘17 2SS A8. Gotta say the A10 was *constantly* hunting for the right gear, to the point that I found it damn annoying. You have to wonder if there is a point of diminishing returns in regards to number of gears.
09-22-2018, 12:59 PM | #28 | |
Thank you Al Oppenheiser!
Chevy did a much better job with the programming in the Z. |
