03-01-2023, 08:04 PM | #1 |
Drives: 2017 Camaro SS Join Date: Nov 2022
How to get rid of choppy helicopter noise
hello all, my '17 SS has 1 7/8 in long tube headers & corsa extreme axle back. I'm having this issue when I go from low RPMs to higher RPMS, the exhaust makes a choppy sound almost like the sound of a helicopter. Has anyone else had this issue or how to fix it? thanks
03-01-2023, 08:53 PM | #2 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Did you just have the exhaust work done? And did you swap the X-Pipe?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
03-01-2023, 09:47 PM | #3 |
03-02-2023, 12:55 AM | #4 |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
please do a video
03-02-2023, 06:48 AM | #5 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
I don't have this issue, but I replaced my X-pipe as well.... running 2" TSP headers, x-pipe with high flow cats, and Corsa NPP axle back exhaust. Assume you have NPP exhaust as well? Someone suggested a video which is great. Could you upload that so we can hear?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-02-2023, 08:16 AM | #6 |
Sounds like the AFM valves in the X pipe might be "fluttering". I have read a few others having a similar issue.
2016 NFG 1SS A8
03-05-2023, 03:27 PM | #7 |
03-05-2023, 03:28 PM | #8 | |
03-05-2023, 03:29 PM | #9 | |
03-05-2023, 05:03 PM | #10 |
Drives: 2023 2SS 1LE Join Date: Dec 2022
I think I had heard this issue in the past from other users. Did this exhaust sound issue happen right after you got it installed? It's possible it's vibrating at a certain frequency and possible hitting something underneath. If you can easily get it in the air, see if the exhaust is close to any cross members or anything and see if may be hitting.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold- 2016 Grey Chevy Volt -Sold- 2018 Blue AWD Kia Stinger GT2 -Sold- |
03-05-2023, 06:41 PM | #11 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
03-06-2023, 07:51 AM | #12 | |
I guess when they put the axle back on it could cause the mid pipe to rest and rattle against the cross member brace. In my case I replaced the stock x-pipe for after market and the pipe settles and rattles on the cross member brace. Simple fix shimmy the cross member brace if that is the issue.
03-06-2023, 07:59 AM | #13 |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
So longtubes with corsa extreme?? Thats your problem. You need to put the stock NPP back on. This is EVERY SINGLE PERSON that gets long tubes after having a catback/axleback installed and its just too loud and obnoxious. Put the stock NPP back on and sell the corsa stuff.
03-06-2023, 08:11 AM | #14 | |
Tags |
exhaust |
