dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 10-14-2009, 10:27 AM   #1
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: was 2010 2LT RS 2G1FC1EV4A9103434
DIY - AeroForce Interceptor Gauge Install
Installation of an AeroForce Interceptor gauge
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
tjd24 is offline   Reply With Quote
Old 10-14-2009, 10:57 AM   #2
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
The interceptor is a rad little gauge. I've thought about it for my LS1. It would be nice to know my trans temp.
Old 11-22-2009, 07:16 AM   #3
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
I am getting the duals later on. I still have no idea on where to mount them. The pillar pods aren't ready yet, and haven't heard much about them lately.
HeavyD is offline   Reply With Quote
Old 12-06-2013, 05:34 PM   #4
I'll post up a few pics of my install.
Pull the rubber back and pop the top of the A-pillar out.
You can see the safety clip here that you will need to pop off and re-install on the new Pod Pillar
I just pulled the bottom of the A-pillar out and twisted it around to get a hold of the clip to easily slide it forward and off
Notice the tab that releases the clip.
Pic of the stock A-pillar removed
Pic of the Autometer Gauge pillar and the silver mount where the clip will slide back on
Pics of where I tucked the extra wire. Note: I have radar detector and footwell wires in here as well so it's a bit messy.
Pic of the OBDII plug. Save this til last and just plug and go.
Just showing the back of the gauges after installed and the small plug attached. This plug only goes one way (slots on the side and ribs on the front) Make sure it is pushed in all the way or it will easily unplug itself.
Once gauges are plugged up and the clip is installed on the new pillar. Stab the end of the Pod Pillar into the slot and push until everything lines up. Peek in the top (Pic #1) to ensure the pin on the clip is lined up to snap the top side back in and you're done.
Before you plug everything up do a test fit to make sure the gauges turned so they are level when installed. I guessed at it the first time and was way off.
Old 12-06-2013, 05:51 PM   #5
nitto85
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette
Any videos of the install? I called a shop local to me about doing the install, and just to install the gauges was $300 ($150 per gauge). I have been sitting on these gauges for probably a year or so lol.
nitto85 is offline   Reply With Quote
Old 12-06-2013, 05:57 PM   #6
These are virtually plug and play. Can't see anyone charging over 30 bucks to install.
The A-pillar pops right off and I provided a good pic of how the clip comes off of the stock one.
Pop off the side fuse panel as well and just tuck the extra wires in where I circled. I think the hardest part was plugging the small plug up to the back of the gauge. Before I snapped the new A-pillar into place I turned the key on and made sure they came on.
Really not much to it.
Old 12-06-2013, 07:08 PM   #7
nitto85
Caffeine Injected
Thank you for adding the text for each step, definitely helps out.
I can't wait to install mine, had no idea it was so easy. Hopefully the weather is nice enough tomorrow for me to do it.
I don't think I'll be able to read boost pressure until I have a shop install the new ZR1 map sensor though. The shop I mentioned above, wanted to do a complete retune to install the sensor, another $300 - $400 I think. So the gauge install would have ran me $600+ if I had went with them.
Old 12-06-2013, 07:15 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
In order to read boost correctly with zr1 sensor, you will need a tuner to input the necessary adjustments. Im on a phone or I would link threads but a search will turn them up.
Installing the sensor is as easy as unplugging the wiring and removing a screw. Pulling stock sensor out and putting zr1 sensor in, replacing screw and plugging connector back in. 5 minutes at the most
Old 12-06-2013, 07:42 PM   #9
nitto85
Caffeine Injected
Yeah I know, but this shop was telling me that they had to do a complete retune, because they used different software than my previous tuner (ATLPF.com).
I don't know if that is true or not, but I know the MAP sensor install is easy, the tune adjustments is what is holding me up. I'd rather not get a complete retune if I'm not upgrading any parts.
Old 12-07-2013, 03:10 PM   #10
I'd stay clear of that shop. If you have further questions on something tune specific post up a new thread or ask the guys in this thread. That's what the forum is for.
Glad the text helped.
Old 04-01-2015, 09:47 AM   #11
BattleScarredSoldier
BattleScarredSoldier's Avatar
Drives: 14 Camaro ZL1, 87 Grand National
CEL and other issues with install
I installed mkne relatively easy, setup the gauges no problem. Turned the key to start my car and it wouldnt start until i unplugged them! When it did start the CEL was on. Plugged up the gauges while the engine was running and my dash started displaying a few different service codes to include power steering and traction control. Also the analog tach was all over the place! Im calling aeroforce today but has anyone else experienced this?
Vengeance Racing + Cat and Muffler Delete > Viagra
BattleScarredSoldier is offline   Reply With Quote
Old 04-01-2015, 09:58 AM   #12
WoW... that's crazy. I have not heard anything like this happening.
Old 06-19-2015, 03:33 AM   #13
Yeah unfortunately i got called up to come back to the middle east shortly after that so i never got a chance to get it sorted out. My poor car is just sitting in the garage with some really nice but inoperable gauges lol.
Old 06-19-2015, 09:20 AM   #14
Oh WoW... Maybe we can try them on a different car and see what happens. Hope you're back in the states now. Deployments suck and I'm sure you're tired of it by now, especially with a sweet ride in the garage.
ADM PERFORMANCE DOES CUSTOM AEROFORCE INTERCEPTOR INSTALL ON CAMARO ADM PERFORMANCE Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 50 08-06-2016 12:11 PM
DIY : Radar Detector Hardwire Install Macamaro Camaro DIY & HOW-TO instructions & discussions 179 07-29-2014 07:30 AM
DIY Rally Stripe Graphic Installation Tips (wet install) SUPERSPORTED Camaro DIY & HOW-TO instructions & discussions 26 10-11-2010 02:36 AM
AeroForce Interceptor Gauge Install tjd24 Audio / Visual / Electronics/ Gauges / Nav 7 10-21-2009 08:38 AM
DIY Body Kit Install & Paint scythezo6 Camaro DIY & HOW-TO instructions & discussions 0 08-21-2009 03:04 PM
