Roto-Fab
Old 10-31-2011, 05:11 PM   #1
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: was 2010 2LT RS 2G1FC1EV4A9103434
Lower Control Arm - GM Redesign Status?
I understand that the lower control arm was redesigned by GM to address stress bending/cracking issues at the bracket holding the endlink. Does anyone know if the GM Part # 22743327 is the original bracket or redesigned version? It's call-out #16 in the diagram included. Obvious I'd want to order the redesigned version to avoid having future issues.
The pic shows the damage to my driver side lower control arm at 23,000 miles. The endlink was still attached to the bracket, I heard a loud "thump" from the rear of the Camaro when making sharp left turns in the prior month to seeing this, though you can see the stress cracks after it was unbolted. I'm using the Pfadt Rear Lower Control Arm Reinforcement Bracket to bolster the OE control arm bracket until I can get the redesigned part -http://www.pfadtracing.com/catalog/product_info.php/cPath/51_52/products_id/242
Many thanks to Matt at East Coast Supercharging for his help on this issue.
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
tjd24 is offline   Reply With Quote
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 06:22 PM
Camaro Control Arm failure analysis and solution PfadtRacing Suspension / Brakes / Chassis 114 07-21-2011 02:38 PM
REAR lower Control ARm? Capthowdy Suspension / Brakes / Chassis 25 05-03-2011 04:42 PM
