09-04-2010, 12:29 PM | #29 | |
Drives: RY 2LT/RS Join Date: Jul 2009
Airaid Intake And Solo CatBack Solo Highflow Cats |
09-05-2010, 07:51 AM | #30 | |
Zeta Brother to Camaro
Glad to hear the J-pipes worked out so well for you! --zep
2009 Pontiac G8 GT SOLO Performance HF-Cats & SOLO Mach Unbalanced Catback with drone-free J-pipes |
09-05-2010, 10:29 AM | #31 |
Deep6
Drives: 2016 Camaro #182300 | 2SS | HBM Join Date: Apr 2009
Thanks Zep. That makes sense. I was getting carpel tunnel from all the cleaning. Now all I need is a solution for break dust.
Noisemaker, good meeting you too.
My Journals: Erick's Mistress - Violet 2016 2SS #182300 | 2SS | HBM | Erick’s Mistress - 2010 2LT #8212 | 2LT | RS | CGM | Litho #165 | |
09-05-2010, 10:22 PM | #32 |
Thank you Oshawa/St.Cats!
Drives: was 2010 2LT RS 2G1FC1EV4A9103434 Join Date: May 2009
Glad to hear your experience with the J-Pipes Erick - they make a world of difference.
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
09-06-2010, 11:22 AM | #33 | |
Drives: 2010 Camaro 2LT RS Join Date: Nov 2008
09-07-2010, 07:03 AM | #34 | |
Engine using less fuel (less fuel wasted in exhaust pipes) = better fuel efficiency = Good!
09-07-2010, 08:30 PM | #35 |
Deep6
I can see that it may run leaner and more efficient, but won't this run hotter? I imagine the extra fuel may be needed to cool off the heads.
09-07-2010, 09:23 PM | #36 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Also leaning past stock or some ratio near it can pull timing to protect the engine with 11.3/1 cr? Why airaid cai had problems, to lean and had to redesign to keep close to stock AF.Maybe on exhaust side is o.k.?
09-08-2010, 10:12 AM | #37 |
Not sure on either account... but I do know that the cooling system in modern cars is very efficient. Also, if your ECM detects a 'too lean' condition, it will throw off a CEL, like if the base tune is more than 20% too rich or too lean, it'll throw the check engine light. So if you have no light, I don't think there are any ill effects, as far as the ECM is concerned. The engine is just a glorified air pump, and you just made it a bit more efficient at exhaling, that's all.
09-09-2010, 10:03 PM | #38 |
Deep6
I helped on the exhale with the Hi-Flo cats and inhale with the Roto-Fab CAI.
09-09-2010, 10:19 PM | #39 |
looks cool
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
MagnaFlow Axle Back w/ Mufflers - Install and Review (now with drone!) | themossman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 07-12-2010 09:56 AM |
Cat back Vs Axel back | MillerTime | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 05-06-2010 01:12 AM |
Headers & Cat Back Exhaust | SamSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 39 | 01-08-2010 10:26 PM |
Headers or Cat back? | H & E | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 31 | 07-01-2009 01:26 PM |
question on install: GMPP cat back exhaust | detroitboy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 04-04-2009 12:52 PM |
