07-07-2020, 09:52 AM | #1 |
Drives: 2020 LT1 Join Date: Dec 2019
28"....what gear/rpm through trap?
Curious if youre still in 3rd? My 275/40r17 is 25.7" i think. Im around 5k in 4th. Wondering if a 28 would help launch rpm and saving a shift.
07-08-2020, 04:49 AM | #2 |
Doesn't a stock M6 go into 4th gear on the dragstrip? And your car has a higher peak-power rpm than stock, meaning that going taller would be the wrong direction. You should rev that thing in my opinion.
From looking at your time slip, my guess is that you could be getting the M6 bog issue, and also it's possible that the shift points that were used might not be optimal. The 60' and 330' could be the bog thing, which probably contributed to the low mph at mid track. The 117 trap speed also seems low for a 499rwhp car as light as this one. |
07-08-2020, 11:34 AM | #3 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
07-08-2020, 08:24 PM | #4 |
Drives: Chevy Camaro SS Join Date: Nov 2019
I agreed with the statement above. My a8 car trapped 124 mph with 474rwhp.
07-09-2020, 06:31 AM | #5 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Bone stock M6 trapped almost 117, bottom side of 4th thru the lights. Now current Whipple setup going thru the lights top of 4th (5500 ish) @ 132 with 28" tall MT ET Street R bias ply's.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
07-12-2020, 01:25 PM | #6 |
Thanks for the input. My time was in 90 degree/ real humid air. Im hoping better air will bring my MPH up. Ill keep working with my current tire. I cant feel the bog that everyone talks about. Ive got a mamo V2 and roto fab on the way, hopefully those help a bit. Also waiting on MSD 2-STEP, which ships out on the 17th. Figure it should help with consistency and get that 60' down.
My dyno graph showed peak hp @ 6200, so i was shifting around 6500. |
07-13-2020, 05:19 AM | #7 | |
07-13-2020, 05:01 PM | #8 |
Nice, thanks for the input guys. Ill let it rip past 65 and see what that does. I inquired about getting my jntake ported by Pray, but he's 8 week out. I plan to get back out within the next couple weeks, and will report back. Id take 11.80s @ 120+ as a win.
07-14-2020, 04:49 AM | #9 |
With your cam, I seriously think that an MSD and a 95tb is the way to go. MSD is much better in the upper end, which is where your cam is doing it's thing as well. Complementary in other words. Yes I realize that you're currently in the same boat with employment that a lot of people are, so the price is a concern, maybe just wait until things improve before buying something?
07-14-2020, 08:58 AM | #10 |
Stock intake manifold is killing your cams potential...you need a ported MSD/95 combo.
2016 NFG 1SS A8
07-15-2020, 04:44 PM | #11 |
I agree, but 2k for what, 20ish wheel throughout?? Hard pill to swallow. I guess if it carried power for 500 or so more rpm, that would be the bigger benifit. Gotta pay to play, but damn. Cars getting strapped down on august 11th again. Im not expecting too much, just want things to be touched up and the tune be clean as possible.
07-15-2020, 06:25 PM | #12 | |
Drives: like an old lady Join Date: Jun 2012
speaking of intake manifolds, when is tsp gonna release any info their new LT1 manifold?
07-16-2020, 09:41 AM | #13 |
40 would probably be worth it. If TSP's LS3 manifold is 1k with rails, id hope ours would be under 900. Thatd be the move if it proves worthy and doesnt NEED 600 in porting
07-16-2020, 10:58 AM | #14 |
20 if you are only comparing peak... as previously mentioned the big gains are going to be up top past peak where the stock intake is falling off in the area where your cam wants to rev. In order to make a cam car perform you have to rev it higher because the power curve shifts to the right. Your engine is only at peak for a narrow window of time. The MSD will carry peak power much further and the car will be substantially faster because it will continue to pull all the way out to rev limit without falling off. It will also setup the next gear higher in the rpm range which helps a lot.
2016 NFG 1SS A8
