07-03-2020, 06:13 AM | #1 |
Drives: 2016 camaro ss Join Date: Dec 2018
radials vs bias (drag). Alignment attached
Whats the best overall result at the track and street. Seems to me overall that radials do better, my bias tires suck in the street, and there ok at the track, but not great.
07-03-2020, 10:51 AM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Dec 2019
Radials seem to be the way to for 99% of the fastest 6th gens everywhere...
2018 Camaro 2SS A8 Redline Edition
07-18-2020, 09:31 PM | #3 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Fastest m6 cars at the track are on bias ply tires, though on the street a lot go with radials. For automatics radials are the best way to go all around.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
07-18-2020, 09:49 PM | #4 |
Its best if you run the same on front and back. I've run a radial on the back and bias up front but I wouldn't run it the other way. I've had some guys tell me that they've tried to run a bias slick on the rear and radial up front and both said their Camaro were really not stable down track. I think a bias tire is better for a manual car and softens launch since the sidewall will have some give where the drag radial hits the suspension and drive train pretty hard. MT make a bias street R, I wouldn't run that on the street. Tough decision.
07-19-2020, 08:31 AM | #5 |
Thanks for the replies guys, im running f14 17/15 with m&h bias dot up front, love those tires. I was running 28x12.5 et street r's in back, had set up for about 8 months. Never had great results at track and wouldnt hook at all in street unless already moving. Ive got 325/50/15 et street r and they hook and raise the front end in the street. I think i'll get a personal best on these when I get to the track.
07-19-2020, 10:12 AM | #6 |
Why not run the et street r bias on the street? I was planning to try that next with stock radials up front. Interwebs says it’s stiff enough to even be ok that way.
07-19-2020, 01:37 PM | #7 |
They drove great on the street, I just had issue hooking them in the street and at the track they would hook and unload slightly on me, to me they were to soft of a side wall, I cut 1.48-1.52 60' with the bias. I think the radials are going to do better
07-19-2020, 01:40 PM | #8 |
Here's my alignment if someone can take a look at it. Thanks
07-20-2020, 06:20 AM | #9 |
Looks like the toe could be closer on the Front and rear. I didn't have any negative camber for my drag setup. When the car launches it goes negative when it squats and when I had it set up too negative I could see it in pictures that were taken of my car at Super Chevy so we changed the camber to 0 and it started to hook better because it had been running on the inside of the slicks when in launched.
07-22-2020, 08:57 AM | #10 |
Layno can u comment more on the bias street r?
07-22-2020, 07:54 PM | #11 |
I'll get toe closer and I'm going Friday, and get it 0 or maybe +.1 or .2 on rear camber
