2020 Shadow Gray 2SS
Is anyone running 275/35/20 with MRR017 (+23 offset) on an MRC SS?
If so, have you experienced any rubbing issues? What brand/model tire are you running??? I am currently running Atturo AZ850 285/30/20's on my MRC SS with MRR017 Wheels (+23 offset)... Is anyone running a similar setup with 275/35s? I'd ultimately like to go to 275/35 up front and 315/30 in the read but I'm very concerned about clearance on the fronts with the suspension... Any input would be greatly appreciated...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
Hey Mark, I had this setup (MRR 017s and 275/35/20 front, 315/30/20 rear tires) before I finally found a set of genuine 1LE wheels, and I'm going to switch back to these tire sizes once my current set wears out.
I used 3mm spacers to be on the safe side, and the picture below shows how much suspension clearance I had with them up front. If my memory serves right, I think you may get away without the spacers, but it'll be extremely close, and depending on the tire, you will likely rub that center rubber nipple off. The factory 1LE wheels have exactly this much offset difference, so no spacers needed with those.
#3 | |
