07-09-2020, 01:41 PM | #15 | |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
07-09-2020, 02:22 PM | #16 | |
Drives: 2017 Hot Red 2ss Auto adrenaline Join Date: Aug 2017
Unless something crazy happened on different days i saw the m3 going faster then the 1les at nationals, wouldnt a m3 move to B street make more sense or do m3 owners have to much "influence" |
07-09-2020, 02:30 PM | #17 |
Drives: N/A Join Date: Feb 2020
It's hard to compare Lincoln results on different days, the weather is often too different.
'17 SS 1LE.
07-09-2020, 04:34 PM | #18 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
In another thread, I suggested that one of two things should happen:
The premise for #1 is that the M3 is an obvious overdog in FS and it does not fit the intended concept of the class at all: the best one was a $70k car in 2013 and good used ones today still cost as much or more as a brand new SS 1LE. Most people aren't willing/able to pay that much for a car that's already at least 8 model years old. That's naturally going to drive down entry numbers in FS compared to all those who own recent SS or GT pony cars but who don't want to bother entering a class where they really have no chance against an elite German car. The E90 M3 seems to be a pretty good match for an SS 1LE, so it would fit in BS. The new Supra seems like an AS car in every way, although we won't have a really good idea until Nationals this year, most likely. The premise for #2 has been pretty well stated already. The bottom line there is that the 1LE is really just an option package for the Camaro, so it isn't especially rare or unobtainable and could be thrown in FS with the other ponies. The GT350 is a different kettle of fish, though: pretty expensive and relatively rare (only a few thousand each year, and production has ended), as well as explodey. But maybe the new Mach 1 will solve that. The obvious problem with this plan is that it doesn't get the non-track-pack ponies back in class. Like others, I don't understand the point of moving everything from FS to BS and reinventing FS as something completely different. That doesn't solve anything.
Matt Miller
2020 SS 1LE |
07-09-2020, 06:10 PM | #19 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I disagree, too much difference in tire size. Unless rules are changed so base models are allowed to run the track-pack tire sizes it's not even close to fair.
07-09-2020, 08:16 PM | #20 |
It seems pretty unlikely for them to move the M3 to BS imo. I’m not sure there’s been an ‘old’ car that did so well in a class for so long and then being bumped up. I feel like almost always a new car is added to that cars class to dethrone it instead.
I personally think it’s okay if the normal SS are outgunned. Not every car can be the best one in its class. If you haven’t already I definitely recommend writing a letter to the SEB and sharing your thoughts. I’m hoping they’ll be some sort of decision soon, though at this point I expect it to be effective next year.
'17 SS 1LE.
07-09-2020, 08:23 PM | #21 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
If anyone caught the SCCA Town Hall last night, this issue was addressed directly by Mike Cobb, Heyward Wagner and Bob Davis (SEB Chair).
He said the issues they are trying to address are: 1 - Solo has too many classes 2 - You often have to have a new car to be competitive in a class As for the OP's post. That was just a proposal. Nothing has changed yet.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
07-09-2020, 09:08 PM | #22 | |
That said, I think the better move is bumping the M3 to BS. You could add a few numbers to that class, and then you have the chance to shore up FS numbers with SS and GT owners, of which there are probably over 100,000. Unfortunately, this isn't one of the proposals being studied. But if they did do this, then I'd want them to take a close look at the new Supra and M2 Comp to see if they aren't a better match for AS.
Matt Miller
2020 SS 1LE |
07-09-2020, 09:15 PM | #23 | |
Matt Miller
2020 SS 1LE |
07-09-2020, 10:19 PM | #24 | |
07-09-2020, 11:33 PM | #25 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Can't you still update/backdate if the car is on the same line? Other than the eDiff, all the 1LE parts could be installed on a standard SS pretty easy.
What was the rule that aged out cars? At what chassis age does a car not qualify for Street(Stock) anymore? Or did they do away with that? When I got back into solo with my Camaro, I said screw it with Street and went to CAM. I wanted to run with cars that were similar to mine, having the same hurdles my car has - weight, width, etc. I expected to be an also ran locally because I keep my car nearly stock (Camber Plates and 19x11s all around). I've done pretty well and decided to hit up Nationals for my first time this year. Totally expecting to be outgunned, I'll be happy if I can break mid pack. At least hoping to beat my co driver...
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
07-10-2020, 07:08 AM | #26 | |||
Drives: 2013 C6Z06 Join Date: Nov 2016
07-10-2020, 07:11 AM | #27 | |
You can't update/backdate in Street class, and the cars are on a different line.
The 'sunset' rule is 30 years for Street class. I thought it was 25 but did some googling. Quote:
'17 SS 1LE.
07-10-2020, 07:24 AM | #28 |
The rule basically is that if you want to do one, then you have to do them all. I think it's so that people aren't mixing and matching otherwise illegal parts and making an ultimately faster car than what came from the factory. Much like the "go away" price from a shop that doesn't want to do the work.
