Old 03-31-2023, 09:46 AM   #1
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Dumb question on radiator cap.
How do you open the top radiator cap? The top chamber not the bottom one.
I turn it it gets loose then tightens again wth.
What’s the trick to opening it?
Thanks
NYJets12 is offline   Reply With Quote
Old 03-31-2023, 09:51 AM   #2
adamjwilson
Drives: 2022 Camaro 2SS A10
It does not have a conventional radiator cap like the old style radiators. See the post below this one "Dumb question on bleeding air out of coolant" on servicing the coolant in radiator.
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 03-31-2023, 10:05 AM   #3
NYJets12
NYJets12's Avatar
The black cap on the top chamber I just called it radiator cap but same thing.
I looked at that post but doesn’t say how to open it , I searched it to nothing came up about opening it only filling it.
Old 03-31-2023, 10:28 AM   #4
adamjwilson
Clockwise to close and counter-clockwise to open.. if your cap does not work this way, it may be bad/stripped?
Old 03-31-2023, 10:43 AM   #5
W-Scott
Drives: 2023 Camaro LT1, Convertible M6 sp
That picture was great! I had look looked at my rad fluid and had wondered how that arrangement worked. What I hadn’t noticed before was the second small cap for the lower tank. The reason was on my convertible the strut tower brace is basically on top of it and hides it from view (kinda unfortunate……)
This makes a lot more sense now! Thank you!
W-Scott is offline   Reply With Quote
Old 03-31-2023, 01:35 PM   #6
NYJets12
NYJets12's Avatar
Do you have to press down on it to open it? Like those easy to open pill bottles.
I looked on YouTube some cars you do , didn’t find a Camaro yet. After it stops raining I’ll see if that works.
Old 03-31-2023, 02:52 PM   #7
adamjwilson
I just turn mine without pushing down?????
Old 03-31-2023, 03:01 PM   #8
easttxss
easttxss's Avatar
Drives: '16 2SS M6
You aren't trying hard enough. Put more effort into it and it will unscrew.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 03-31-2023, 05:33 PM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Make sure the lower coolant tank is half full.
Old 03-31-2023, 05:35 PM   #10
W-Scott
Just tried mine 3 and 1/4 turns anti clockwise to remove.
Old 04-01-2023, 06:48 PM   #11
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Just keep turning the cap and it always comes off. Key wording is turn, turn, turn, turn.
lt4camaro is offline   Reply With Quote
