10-29-2020, 10:14 AM | #1 |
Drives: 2018 1LT Camaro Join Date: Aug 2017
After your shudder flush question?
I’m at the dealer getting the flush and new fluid for the shudder, they told me if it still does it after 500 miles they do the torque converter,
My question is how many miles did the dealer tell you to drive to make sure it’s gone. I seen one post on here somebody said 200 miles just curious what your being told . Thanks
10-29-2020, 10:30 AM | #2 | |
My 2 cents: Sounds like you have a very agreeable dealer. If you have any concerns at all, I would go for the new TC. If you think there is vibration, the dealer should be able to verify TC as the source using this procedure: https://gm-techlink.com/?p=11127 How many miles do you have on existing TC with shudder problems, and how long have you had shudder? Having seen the pictures of surface wear on the clutches I would not be happy having them in my car, even with all new fluid. The situation is such that the plates will never wear smooth again. It's a type of skip chatter wear. I can only see it getting worse over time. |
10-29-2020, 11:08 AM | #3 |
Drives: 2017 Camaro 2SS, MRC, NPP, Join Date: Jul 2016
200 miles. the first flush i got done lasted 4k miles before it came back. once the TSB that came out with thee new fluid came out I got it changed again and this last one is pushing 8k miles with no issues.
10-29-2020, 11:32 AM | #4 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
My dealer told me around 200 miles in a sort of vague non descriptive way. But I also had the TC replaced at the same time
10-29-2020, 11:42 AM | #5 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I had the flush done in May 2019. In August 2020 the shudder came back. They replaced the TC and put in new fluid.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
10-29-2020, 12:08 PM | #6 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Told me it may continue to shudder mildly for a few hundred miles. I may have felt it very mildly once or twice within that time. Traded it in about 1K miles afterward.
10-29-2020, 03:00 PM | #7 | |
1 1/2 months ago I had it twice for about 2 seconds Last week I had it 3 times within 2 minutes driving up a slight hill( longer than 2 seconds) and once Monday and Tuesday of this week. Hope the new fluid and flush works.
10-29-2020, 03:11 PM | #8 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
i did my own flush a few months and a thousand+ miles ago. no shudder behavior since. But I caught mine while it was still so mild that only I could feel it thru the pedal.
I'd think 500 miles is plenty on actual new fluid. If you have perm damage, it's not going to matter much if the fluid is new or not, you'll feel the shudder or other shift related abnormal behavior real quick. A lot of the delayed return issues from other people are from being flushed with pre-2019 fluid. I'm not sure if the guy above who had it done in may 2019 got the brand new blue label fluid or if they gave him black label ... but i know even into 2020 you'll still find black label being sold in stores rather than the new blue label so it wouldn't surprise me if dealers were a bit laggy in switching their stock to blue if they had tons of black. |
10-29-2020, 03:51 PM | #9 |
Drives: 2020 Camaro RS Join Date: Oct 2019
When I had it done on my 2018 Colorado, the Service Manager said it had to be driven "a minimum of 200 miles" before GM would consider a new TC. I drove mine about 225 miles after the flush and before the new TC. They replaced my TC and the new TC stayed healthy until I traded my Colorado for a Silverado a couple weeks ago.
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
10-29-2020, 05:18 PM | #10 | |
Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
10-29-2020, 08:24 PM | #11 |
I believe my dealer told me between 200-500 miles. I just went with it and 0 issues after 8k miles. (Never had the shudder prior)
10-29-2020, 11:07 PM | #12 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
No shudder immediately after the flush on my wife’s CTS, but it went in within days of first sign of it.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
10-30-2020, 06:09 AM | #13 |
Drives: 2018 Chevrolet Camaro SS 2SS Join Date: Aug 2020
200 miles and two full heat cycles
10-30-2020, 11:13 AM | #14 |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
I had mine flushed twice. Last time with the new fluid and no issues. My pickup also has the A8 and was flushed with new fluid and driven hard for last 5000 miles with no issues. The pickup had the shudder for a good 6 months (3000 miles) before I got it flushed.
