Old 01-10-2019, 05:32 PM   #1
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
Suspension vs Wheel Size & Offset
I'm wondering if a Camaro 2.0T with 18x8.5 32mm offset wheels from the factory and a Camaro 2.0T with 20x8.5 25mm offset wheels from the factory have identical or different suspension setups?
PDXSSCE is offline   Reply With Quote
Old 01-11-2019, 03:10 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Yes, they should both have identical suspensions (FE2 RPO code). Only time a 2.0T camaro would have different suspension is if it's a 1LE.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 01-11-2019, 06:53 PM   #3
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I don't understand the reason that the 18" and 20" offsets are different, when the width of the wheels are the same? I thought the diameter is unrelated to the offset.
Old 01-11-2019, 08:39 PM   #4
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
The offset is independent of the diameter. The lower offset (given the same width) will push the wheels out further for a more aggressive stance.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 01-11-2019, 08:54 PM   #5
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I understand, so from a performance aspect, is the higher offset (if the diameters were equal) better because it brings the wheels in?
Old 01-11-2019, 11:22 PM   #6
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
To figure out why the offset is different, you need to look at the OD of the 18" and 20" setup. If they are the same OD the offset would be the same for both. But if the OD is different, the change in offset will help maintain the desired scrub radius.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 01-11-2019, 11:50 PM   #7
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
If wheel diameter doesn't affect offset, why does tire diameter affect it? Is it a matter of clearance?
Old 01-13-2019, 10:38 AM   #8
vtirocz
vtirocz's Avatar
The 18" setup's tires (245/50-18) have an OD of 27.6457".
The 20" setup's tires (245/40-20) have an OD of 27.7165", or about 0.07" different from the 18" setup.
That's pretty close.
Old 01-14-2019, 09:12 AM   #9
Alpha1BC
Alpha1BC's Avatar
It could possibly be a brake clearance thing? 20s are meant to fit the SS package with the 4-piston Brembos, and I'd assume that brake package requires more room than the base floating caliper on the LTs.
2017 SS 1LE.
Old 01-14-2019, 01:52 PM   #10
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Wheels pushed out more just look better.
GM wants to give you a reason to upgrade your wheels when you buy the car.
Old 01-14-2019, 07:45 PM   #11
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Yes, it makes sense, but unfortunately it affects the scrub radius.
Old 01-17-2019, 02:54 AM   #12
JaxChris
If you want the outside face of the wheel to stay in the same spot when you go to a wider or thinner wheel, the offset must change to keep the mounting interface at the same place with the hub face.
Pretend this is the top down view of your front left wheel and you want to keep the outside (left) edge of either wheel flush with the fender.
|----i------|
|----i----|
On the thinner wheel the offset is 0 (middle), but to keep that front left wheel at the same outer position, the wider wheel needs to move the offset away from the middle.
Old 01-17-2019, 08:07 AM   #13
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
|----i------|
|----i----|
I understand that part. It seems that one must choose between appearance and handling when choosing aftermarket wheels because of the scrub radius. The wheels sitting further out look better but it affects how the car handles.
