05-11-2022, 09:44 PM | #1 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
Battery
So car has been slow cranking only in the morning. I had it tested and O’Reilly said it’s still good?? I bought a new AC delco one from Chevy anyway.
Any thoughts that the battery just won’t hold a charge overnight? It is 4 years old and has never seen a battery tender…. Headers a ceramic coated and the starter is wrapped so I’m hoping it’s not a started issue. But I guess I’ll find out in the morning.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
05-11-2022, 09:54 PM | #2 |
Could still be the starter, indirectly, because of the crappy grounds these cars often have. Have you considered the "canonical" fix of adding a new ground strap or two as described here: https://www.camaro6.com/forums/showthread.php?t=586153 ?
It helped my Camaro tangibly with warm and hot starts, even though it had never failed to start, the starter was clearly struggling before adding a big thick strap. Now it's much quicker and expends less effort, even with my 4-year-old original battery.
05-11-2022, 10:54 PM | #3 | |
I tested the batter after arriving home from work about 1hr of drive time. I should have tested it in the morning. We’ll see what in the morning what happens.
492WHP 473WTQ |
05-11-2022, 11:02 PM | #4 | |
Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
05-11-2022, 11:05 PM | #5 | |
Funny, my explorer had the same symptoms but only when it was hot and it wouldn’t start at all. Started fine cold. Replaced the battery and all was good. Battery was so bad that the doors wouldn’t lock with the fob.
492WHP 473WTQ |
05-11-2022, 11:37 PM | #6 | |
05-12-2022, 10:17 AM | #7 |
i had mine replaced by gm after 3 years then last year i upgraded to a antigravity battery no issues since
05-12-2022, 12:11 PM | #8 |
Well it’s started up strong this morning so I guess the battery was on it way out. Also had a few gallons of 91 in it to smooth things over so who knows. Just glad it wasn’t the starter
492WHP 473WTQ |
05-12-2022, 12:47 PM | #9 |
Drives: Chevy ss sedan, 22 ZL1 vert Join Date: Jul 2021
FYI the positive cover that came with your new battery (red) has plug/cap built into it that can be twisted off for the vent.
https://gm-techlink.com/?p=8326 |
05-12-2022, 12:52 PM | #10 | |
492WHP 473WTQ |
