Old 10-25-2017, 02:27 PM   #1
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Thumbs up RPM 1,000hp 6th Gen Camaro Build | Pics & Video
Figured we would start a build thread for this car we are doing for a customer.
The original plan was to just do forged pistons in the stock LT1, but after talking with the customer and discussing his goals/plans for the car we knew we had to step it up a bit more.
We gave a ring to our buddies at LME (Late Model Engine) and spec'd out a 416ci LT1. Complete with
- Callies Magnum Series Stroker Crankshaft
- Callies Ultra Billet 6.125" H-Beam Rods
- Wiseco/LME Custom Forged Pistons w/Upgraded Heavy Wall
- Clevite H Series Main Bearings
- ARP LT1 Main Stud Kit
- Balanced and Blueprinted
We are also going to be doing
- RPM Custom LT1 DOD Delete Camshaft Package
- F1-A Procharger
- American Racing 2" Long Tube Headers w/ 3" catless x-pipe
- RPM Custom Low Side Fuel System w/ LT4 Fuel Pump and LT4 Fuel Injectors
- ProMeth Methanol System
- Monster LT1-S Triple Disc Clutch
Tear down begins
Out with the old
The LME engine arrives
We are going to be upgrading the valve springs, pushrods, etc, but using the stock heads.
Cam is in.
We will add pictures & video as we go
Some updates will also be in our youtube web series so make sure to check it out.
Frans96ss is offline   Reply With Quote
Old 10-25-2017, 02:39 PM   #2
PRAY
PRAY's Avatar
Drives: 2016 2SS
Sick.
Old 10-27-2017, 02:41 PM   #3
Frans96ss
Frans96ss's Avatar
Drives: 96SS
some coverage of the build in today's episode
Old 10-28-2017, 06:44 AM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Should be a bad ass ride.
Old 10-30-2017, 07:40 PM   #5
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
I'm sure it will be badass. Kinda odd thought that he's spending $$,$$$, yet still just going to use the factory heads. Either way, I look forward to the numbers.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 11-01-2017, 12:50 PM   #6
Frans96ss
Frans96ss's Avatar
Drives: 96SS
A little more progress.
Old 11-02-2017, 09:32 PM   #7
Swagger
DaWolfOfAllStreets
Drives: 17 C Coupe, 17 1LE, 16 Scion iA
If I am NA and pulling in air then intake manifolds and heads become a big part of making power. However if we pushing air in via the blower or turbo. Having heads and an intake become less of an issue... Thats not to say that having heads done wont yield HP but the HP vs $$$ ratio makes it a want to have & not a need to have for me. I may come back with heads and a Procharger intake manifold next year but I plan to just enjoy the car. Some roll races and highway play for me, along with cruising around making discharge noise LOL.
Swagger is offline   Reply With Quote
Old 11-13-2017, 12:05 PM   #8
Frans96ss
Frans96ss's Avatar
Drives: 96SS
On the home stretch now!
The Procharger and Intercooler are on. Just have to finish up wiring the meth and fuel system.
Old 11-13-2017, 01:08 PM   #9
PackersFan26
PackersFan26's Avatar
Drives: 2017 Summit White 2SS
Man this things gonna be a monster. Any plans for driveshaft/half shafts?
Follow me on IG: @lip_stick.ss
PackersFan26 is offline   Reply With Quote
Old 11-13-2017, 01:46 PM   #10
Swagger
DaWolfOfAllStreets
No plans for either one, for my intended use I don't think we will need it. This is a roll race, highway monster. Never gonna see a 1/4 mile or get launched aggressively.
Old 11-13-2017, 02:17 PM   #11
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
With that in mind there area plenty of 6th gen Camaros on stock drive shafts and axles. I have gone 1.4 60" on stock everything. They are fairly strong when taken care of (as with everything). Also on the head porting I agree completely. I don't remember where, but I read that our heads are 360+ cc and with the boost they will FLOW plenty.
Turbo_RORO is offline   Reply With Quote
Old 11-13-2017, 03:31 PM   #12
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
what is being used for fuel? e85? MS109? C19?
This is going to be one BIG TIME roll monster... But I will say with that much power rolling on slicks or DRs (nothing else will handle this power) you're still compromising the drivetrain. I'd at least get a loop. Just in case.
I'm barely pushing 630whp and my 2nd gear is nonexistant on nt555 g2s. I can roll into 2nd and still lose it at about 5k causing the shift to 3rd to be premature or cause some bog. I still reel any normal car in no problem...
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol //
(purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills)
// 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap //
exxit is offline   Reply With Quote
Old 11-13-2017, 03:32 PM   #13
exxit
NVM i should learn how to read haha
Old 11-13-2017, 03:43 PM   #14
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
LT4 pump/injectors fuel lobe on the cam and a low side pusher pump for 1000whp?
What am I missing here? I doesn't seem like it's likely to make that much power without a bigger hpfp/injectors
*edit* - ah, meth system on top... got it.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
