Old 06-27-2017, 10:10 AM   #71
MANNAXMAN
MANNAXMAN's Avatar
Originally Posted by 501SS View Post
I used 3m only on top portion so I wouldn't have visible drill holes. Just in case if I decide to remove them later on. I Riveted underneath. Two car washes later no issues.
Is there a gap between the ACS rocker and the stock rocker because of the 3M tape? If so, is it very visible?
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 06-27-2017, 08:06 PM   #72
AxiomVerge
AxiomVerge's Avatar
Drives: 2017 Mosaic Black M6 1SS Vert
In that same vein, what thickness of 3m tape did you use? (Received my rockers yesterday but want to install this weekend)
Sent from my SM-G935T using Tapatalk
2017 Mosaic Black 1SS Convertible M6 / MRC / NPP
Magnuson Heartbeat, Rotofab
Previous:
2008 Corvette Convertible
2007 Pontiac Solstice GXP
AxiomVerge is offline   Reply With Quote
Old 07-02-2017, 09:27 PM   #73
AxiomVerge
AxiomVerge's Avatar
So I finally ordered and installed these. Sorry my car is a bit dirty but if I didn't take these pics immediately I never would.
I had to remove my front GM splashguards for them to fit...someone with way more skill than me could have dremeled them or something to fit but I felt at least 50% sure I would butcher them if I did that.
I used 3M tape on the top part instead of rivets. There is indeed a tape-width gap that I tried to show in my pics, but due to how the plastic is shaped it sort of pulls away on its own, and with just rivets I think the gap would be even bigger (plus now you have holes in your exterior). I put the tape about a half inch from the top because I discovered if I put it flush with the edge you could see it, and it would probably collect dust, which you could also see.
Previous:
Old 02-05-2020, 06:10 PM   #74
Phil 2018SS
Drives: 2018 Camaro SS
How many holes will be visible per side if removed?
Phil 2018SS is offline   Reply With Quote
camaro rockers, zl1 rockers, zl1 side skirts
