09-29-2017, 06:56 AM | #1 |
Drives: 2011 2SS/RS Join Date: May 2014
Thoughts on Thompson Motorsports?
I'm looking to completely rebuild my car into something I can take to the track often. I was looking at building a 427 lsx for a twin turbo set up and stumbled across this set up here http://www.thompsonmotorsports.net/p...roducts_id=533. Was just curious if this is a good deal or something worth investing in.
"Scarlett" the Black Widow
BTR Stage 4 Cam, FTI 3600 Stall Converter, GM 3.91 Gears, GPI Intake Mod V2, CAI Cold Air Intake, SLP 25% Underdrive Pulley, LS3 Conversion, PRC Ported/Polished Heads, Stainless Power Long Tubes w/off-road pipes, Borla Atak Cat-Back Exhaust, Tru Cool 40K 482rwhp/425rwtq, Built and tuned by Champion Motors |
09-29-2017, 09:40 AM | #2 |
Goals?
For 25K that's no necessarily the way I would go personally.
I would make an honest assessment of what I really wanted. Once you know what you expect then you can kind of determine the path or method to achieve it. You don't necessarily need a turboed 427 to go to the track. After you spend the 25K on the engine package you will need to improve the rest of the drive line because that turbo 427 will eat a stock clutch, trans and rear like a ham and cheese sandwhich after a hard days work. Just some things to consider and you may have considered those already. If you have, I've never heard anything bad about Thompson. |
09-29-2017, 09:54 AM | #3 |
Drives: All things Turbocharged Join Date: Dec 2010
If you want 1300+whp then that's the kind of engine you need to buy. Thompson is good stuff.
You certainly don't need that much engine if you just want to make 1000whp on pump gas. |
09-29-2017, 11:14 AM | #4 | |
09-29-2017, 11:17 AM | #5 |
I can say I want to make 1000whp, because that would be awesome. I'm also more so looking if later down the road I wanna put more power into it. So my thinking is if I have an engine capable of 1500whp it would be more beneficial than getting an engine that's good only to 1000whp then end up wanting more down the road and having no room to work because of the engine's limitations.
09-29-2017, 11:24 AM | #6 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
Looks all good but i'm sure that turbo kit wont fit without some cutting and fab work
09-29-2017, 11:31 AM | #7 |
Yeah I was thinking the same. I'm not sure if they are built once they're ordered or if they're already pre-built. If they're built after they're ordered they may be able to move things around in order to make it fit with little to no modification to the vehicle. Something I'll definitely ask them about.
09-29-2017, 12:12 PM | #8 | |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
If your doing the work yourself then go man go. If you are soliciting help from a speed shop then I would get them in on what to get because they will know what they have done in the past and what really works or doesn't work. Just sayin.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
09-29-2017, 12:18 PM | #9 |
Drives: 2009 ZR1 Join Date: May 2010
You won't regret having more engine than turbo.
09-29-2017, 12:28 PM | #10 | |
09-29-2017, 12:59 PM | #11 |
That will be a BEAST when ur done!
I am living on borrowed time with this HP level on a stock bottom end but honestly, I don't bang it all of the time. But when/if I get to the track I don't pull any punches
09-29-2017, 01:01 PM | #12 |
IC you are getting a 9". I happen to have a Strange 4.11 gear for a 9" that I would be willing to sell. When Pyle Brothers pulled it to put in the 3.70 they said it had NO wear and was in excellent shape. Don't know if you have seen one but that 9" gear makes a stock gear look like a midget. It is one beefy son-a-gun.
09-29-2017, 01:18 PM | #13 | |
09-29-2017, 01:35 PM | #14 | |
If you look at the big boys (the really high HP stuff) on the various forum Fast Lists, they all are running low gears, so understood.
