Old 03-03-2021, 01:55 AM   #1
UTURNMOTORSPORTS
Drives: Red Camaro
Ati harmonic balancer won’t fully seat
Hi I’m having issues with my ati harmonic balancer huh to fully seat. I try so hard to torque the stock crank bolt to sit the hub down fully but it won’t torque it down any more. I need help. Anyone has advice? Thanks
UTURNMOTORSPORTS is offline   Reply With Quote
Old 03-03-2021, 04:45 AM   #2
Wilka_SS
Drives: 2016 Nightfall Metallic Grey 2ss
You need an installer tool or you'll pull the threads out the crank, also the factory crank bolt wont work unless you shave the collar on a bench grinder.
Wilka_SS is offline   Reply With Quote
Old 03-03-2021, 06:22 AM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
You have to hone them per ATI
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 03-03-2021, 03:49 PM   #4
396ssrat
Drives: 66 Chevelle SS
Which usually isn't much at all, if any. Use anti seize on the inside of the hub where it slides over the crank snout.
It's also possible the woodruff key is binding in the crank keyway.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
