Old 05-18-2018, 08:48 AM   #1
Whatwarranty
Drives: 2016 camaro ss
Lowering with mag ride control
We lowered my fathers car yesterday and found out you have to have the mrc relearned. Took it to dealer and they state they can’t do the relearn because the cats are off the car..... that makes zero sense to me. Any input on this or how it can be done? I see nothing in hptuners so i guess it has its own controller.
Whatwarranty is offline   Reply With Quote
Old 05-18-2018, 08:51 AM   #2
crosive
Drives: 18 zl1
the controller is in the trunk. Under the bose amp if you have that.
It doesn't make sense for them to not want to reprogram it because your cats are gone. I can understand charging to reprogram, but simply refusing doesn't make sense
crosive is offline   Reply With Quote
Old 05-18-2018, 08:53 AM   #3
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
Never heard of this, I'm lowered with MRC and all seems normal.
51FIFFT is offline   Reply With Quote
Old 05-18-2018, 09:46 AM   #4
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
The MRC system is set up so that at normal, static ride height, the sensors are set at a zero voltage reference point. With lowering, you've changed the static height and now have a negative (?) voltage at rest.
While in theory the BCM needs a calibration, the actual difference is nominal in ride quality and the ability of the MRC to work. I wouldn't worry about it.
And BTW, your dealer can't actually change the programing in the BCM to account for ride height differences. The flash for the BCM comes from Chevrolet only and is matched to your VIN number.
Atomic Ed is offline   Reply With Quote
Old 05-19-2018, 02:31 PM   #5
MGD
MGD's Avatar
Drives: 16 Camaro SS
I had mine lowered 2 years ago and did not do anything to the MRC. Runs just fine with the sensors as they are. What happened if you put 150 lbs in your trunk? It lowers the ride height also, do you have to drive by the dealer to get it programmed?
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 05-19-2018, 02:38 PM   #6
Soleil
Soleil's Avatar
I never heard about that. You adjust the suspension/wheel alignment but that’s about it.
Soleil
Old 05-19-2018, 03:32 PM   #7
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I didn't think there were any ride height sensors?
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 05-20-2018, 01:40 AM   #8
Laststandard
Drives: 2018 1SS 1LE
If you have mag ride, there's a sensor at each wheel that tells the controller where the suspension is in it's travel.
Laststandard is offline   Reply With Quote
Old 05-20-2018, 01:46 AM   #9
Soleil
Soleil's Avatar
+1
In the pic left side of the yellow spring. That little tiny arm.
Soleil
Old 05-20-2018, 01:53 AM   #10
nicktechla
nicktechla's Avatar
I thought the sensor just read impact to determine how much dampening to apply
IG: 2fast2nick
-- Current --
-- Past --
Old 05-20-2018, 11:10 PM   #11
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
No need to bother with MRC calibration plus there is no calibration. Only 1 calibration that was flashed on the car at the factory which is the only one dealer can flash back. Vettes did get a new MRC calibration, maybe we will too... Who knows. Plus from the sounds of it, that dealership also sells blinker fluid? Since they can't reflash MRC calibration because you don't have cats?
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 05-23-2018, 11:43 PM   #12
Whatwarranty
Car would act like you were on ice when going full throttle ass all over the place. We found another dealership to do it 125 bucks and runs perfectly. I personally drove the car and it would not stay in 1 lane while accelerating with 100% traction. They did their thing and all is well I’d say took them 30 minutes.
Old 05-24-2018, 07:08 AM   #13
Soleil
Soleil's Avatar
What did the dealer do????
Soleil
Old 05-24-2018, 09:29 AM   #14
51FIFFT
I lowered mine and only did aliment. No issues up to 150 mph or at the track under 100% acceleration. I wonder what they did? who lowered it? My car drives the same other than its lower now.
