03-27-2017, 09:55 PM | #1 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
Dyno graph and video LT1 vs LS3 (bolt ons) vs Rotrex BRZ
I took my car to a dyno/tune shop (Drift Office - Auburn, WA) this weekend to get baseline numbers. Ambient temps were about 60 degrees.
Car is bone stock. 4th and 3rd gear pulls (it looks like 3rd gear pull was a bit off due to lack of the load). It did 419whp and 413lb/ft wtq on Dynojet LT1 (stock) vs LS3 of a Gen 5 Camaro 1LE (header, intake and tune). They're almost identical except the low end torque advantage of the LT1 engine and compared to my old Rotrex Supercharged BRZ !! as you can see you can easily fit a Stage 2 Evo into that gap between the two and the video
03-27-2017, 10:51 PM | #2 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Pics don't work
03-27-2017, 11:02 PM | #3 |
03-28-2017, 06:11 AM | #4 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Nice numbers...it's funny, these cars have the same engine as a regular SS, yet I have seen about five Dyno Jet tests, and on average the SS 1LE's are a little higher. I wonder if the eLSD saps less power? If anything I would have thought the opposite, but this is the fifth one in the 420 range...
03-28-2017, 06:49 AM | #5 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Amazed by torque difference in lower RPM range
Good numbers |
03-28-2017, 09:57 AM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Very nice comparison, thanks for posting!
03-28-2017, 10:05 AM | #7 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
03-28-2017, 10:35 AM | #8 |
マスタング = 遅い
The SS 1LE's tires are wider though, so that would even that out pretty much. The tires differences are pretty small in relation to dyno rollers in either way though...who knows, it's not like chassis dynos are "accurate", especially when compared to a legit engine dyno.
03-28-2017, 12:13 PM | #9 | |
03-28-2017, 12:36 PM | #10 |
Drives: 2017 1LE Join Date: Aug 2016
03-28-2017, 12:47 PM | #11 |
thanks for the info Since the final ratio (3.73) was one of the bullet point items when they first released the 1LE, I was under the impression that those might be different
