03-11-2020, 11:49 AM | #1 |
Drives: Chevy Camaro 2SS RS Join Date: Mar 2020
Exhaust advise
Hello Group, 1st time posting,
i have 2011 2SS RS convertible , i looking for advise on exhaust, in cruising speed i do not want it to be loud, just when i get on it. i like the low rumble sound vs the cracking sound Any advise on brands? also would a set of headers get me the sound im looking for? |
03-11-2020, 12:04 PM | #2 |
Drives: 2015 2SS Commemorative Edition Join Date: Mar 2020
Welcome! I'm new also!
I have a 2015 with the mufflers deleted. Just straight pipes in place of the mufflers in the back. Still have the cats and resonators, so it will pass emissions. Sounds great on start up, and when you get on it. Not as loud as you would think when driving normally. No drone. I have a manual trans. and there is a crackling and popping sound if you are at, say, 3000 rpms and take your foot off the gas, but it's a nice attention getter. lol Very cheap to do. I am actually thinking about putting headers on it to make it louder. You could do the muffler delete for really cheap,(just a matter of cutting the mufflers off and attaching the new pipe),and if you want even more sound get the headers. From what you said, I think you might be real happy with just the muffler delete. Of course you have all kinds of aftermarket complete exhaust system options also. |
03-11-2020, 12:14 PM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
My advice would be long tubes, hiflo cats on stock exhaust system. Add a cai and a solid tune...best bolt on modification you can do for an LS engine.
There are a lot of quality headers out there......but the price range is pretty broad. The results will be the same....just depends on how much you want to spend. Kooks & ARH are at the high end of the price curve. Stainless Works/Stainless Power are middle ground. TSP & OBX are at the lower end. (these are just a sample of header suppliers. there are a few more). All are of good quality and will last longer than your car. I would also suggest scrolling down the main forum page and do some reading in the V8 exhaust/bolt on section. Tons of good information there. Good luck.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-11-2020, 12:16 PM | #4 |
Just be careful. Adding long tube headers to a muffler deleted car is going to make it extremely loud. I love a loud car and even that was too much for me. It was what I call 'Nascar' loud.
03-11-2020, 12:18 PM | #5 |
Is that even if you keep stock cats and resonators or with them removed also?
03-11-2020, 12:54 PM | #6 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
First thing you must take into consideration is if you have a L99 (automatic) or a LS3 (manual). It will make a difference in your decision.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
03-11-2020, 03:02 PM | #7 |
Drives: 2010 Chevy Camaro 2ss/rs TF edition Join Date: Feb 2019
You will not be dissatisfied with a catback from Solo Performance. I went with their Mach X system to go along with my catless long tubes and I couldn't be happier. Zero drone and sounds amazing! Loud when you want it to be and quiet when cruising. Highly recommend
03-11-2020, 03:08 PM | #8 | |
03-11-2020, 03:35 PM | #9 | |
Drives: 2012 Camaro SS Join Date: Dec 2019
I second solo for a nice sound with low drone and interior noise
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-11-2020, 04:08 PM | #10 |
Thanks, I am somewhat mechanically challenged, but trying to learn.
03-11-2020, 04:20 PM | #11 |
+1 for Solo Performance. Their catback system sounds great. Sounds great with LTs also. I just recently added LTs to mine. If you go here:
https://www.camaro5.com/forums/showt...=569544&page=6 Post #80 is where you can hear the Solo Performance catback with Stainless Power LTs.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
03-11-2020, 05:39 PM | #12 |
As I mentioned I just have the mufflers deleted. Can I just put headers on and leave everything else the same, resonators, cats, or will I need a tune, and more work to the exhaust system? Recommendations? Thanks.
03-11-2020, 05:48 PM | #13 | |
If you add headers, youll have to change the cats as they will not fit with the stock set or delete the cats. A tune is also needed as headers can cause you to run lean and will throw codes for the rear cats being further away etc. You can leave the stock resonator there even with headers if memory serves.
03-11-2020, 06:19 PM | #14 | |
