07-13-2020, 07:29 AM | #15 |
Drives: 2019 Camaro ZL1 // 1LE Join Date: Jan 2020
True story. I was at a track event in Savannah, I about half a tank of 108 octane race fuel in the car. Next session the car went into limp mode. The next session I ran half throttle and never went full throttle just to burn off some of the fuel, once I got 93 back in it, it ran fine.
07-13-2020, 09:57 AM | #16 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Burns slower so yes - to squeeze a few hp best bet is run a few points higher than the design octane rating (say 96 for 93 rating), anything more is a waste of money
07-13-2020, 02:23 PM | #17 |
Drives: 2020 ZL1 1LE Shock 1968 Pontiac GTO Join Date: Apr 2020
Its an A10 car.
Ant |
07-13-2020, 02:25 PM | #18 | |
Ant |
07-13-2020, 02:29 PM | #19 |
07-13-2020, 03:38 PM | #20 | |
Drives: 2019 ZL1 1LE Join Date: Jul 2019
signed, M6 owner.
07-13-2020, 04:26 PM | #21 |
Drives: Gen V Viper GTS Join Date: Jan 2018
If you want the most accurate Dyno reading, ask your Dyno operator for the "SAE Correction Factor". Those numbers will be lower than the "Standard Correction Factor" numbers that you provided, but will be more accurate and a better benchmark for future measurements.
07-13-2020, 08:13 PM | #22 |
The shop had done a c7 vette with same motor but with a 7speed, it made 6 more hp but 40 less tq. Not sure why but it is what it is.
As for the sae it's a minimal difference and ill be using same dyno every time. Ant |
07-15-2020, 11:10 AM | #23 | |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
07-20-2020, 12:28 PM | #24 |
Drives: ZL1. Join Date: Nov 2017
A guy has to realistically use SAE to make the numbers real world...that's why that Standard was created.
Also educate me pls...is 10.9 AF Ratio at max RPM in a stock car - what these cars command / produce? Seems lean does it not? At least compared to other Boosted cars.
2018 ZL1 1LE (on order)
2013 Gen 5 Viper GTS https://youtu.be/CI9IJNYG07c 2013 Scion FRS https://youtu.be/TpmKp3pTLcw Chevy Colorado Trailhawk 04 SVT Cobra (sold) |
07-20-2020, 06:07 PM | #25 |
Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
07-20-2020, 06:13 PM | #26 |
Drives: like an old lady Join Date: Jun 2012
i'm jealous of the curve from 5k-redline, especially 6200+. my LT1 dropped like a rock after 6300.
07-20-2020, 06:33 PM | #27 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Really wish people would stick to the SAE standard... STD just inflates the numbers.
Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
07-20-2020, 09:52 PM | #28 |
Drives: 2018 ZLE Join Date: Mar 2020
