Old 09-20-2020, 08:28 PM   #211
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
My apologies if this was cover earlier and I didn’t see it.
What is the ideal TB size after porting the front opening on the LT2 manifold? I don’t want to get a bigger size and not be able to match up the opening which would be a waste. I hear a lot a talk about the 95mm over the stock 87mm. That’s 0.315 inch of a difference, is there any real performance gains that can make the purchase worthwhile?
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-20-2020, 08:32 PM   #212
QuarterMileSS
Camaro6 newbie
Drives: 2020 Riverside Blue Metallic 2SS
Originally Posted by 6spdhyperblue View Post
I have to look at my old slips but I think my fastest mph at this track was 121.5 mph
If you don't mind me asking, what all have you done to your car?
QuarterMileSS is offline   Reply With Quote
Old 09-21-2020, 01:45 AM   #213
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Somebody else said they had to shave into the o ring groove for the seal to get the 95mm to fit right.. my 91mm (ported stock 87mm) had actualy matched up perfect and I didn’t have to shave anything to match it. Anything over the stock 87 will definitely be worth it tho
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
Dvs510 is offline   Reply With Quote
Old 09-21-2020, 12:11 PM   #214
BadGTR
Drives: 2016 Camaro SS
FBO 95tb, ported LT2 intake, cai FF 2” LTs ram-air
275 DR on rear with stock fronts
Full weight besides pulled the rear seat out
Sway bar, skid plate and npp muffler and all that good stuff still on the car.
Run of the mill recipe really
You picked up 3mph with the ls2/95mm tb setup?
BadGTR is offline   Reply With Quote
Old 09-21-2020, 04:57 PM   #215
BadGTR
It’s safe to say the car picked up 1.5mph minimum
I saw some improvements based from my logs on Saturday that I already incorporated and loaded Sunday. looks good on street. I still have a few more trips this fall.
But that 1.5mph was over your stock ported manifold, right?
Old 09-24-2020, 07:53 PM   #216
6spdhyperblue
Drives: 6th gen
Yes
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 09-25-2020, 06:56 PM   #217
madkat7134
Drives: 2016 camaro 1ss
Anyone know what part number is or where to get the manifold bolts I snapped one off and need another. Also any tips on getting the one snapped off out?
madkat7134 is offline   Reply With Quote
Old 09-25-2020, 10:33 PM   #218
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
So has anyone checked air fuel after installing the LT2 manifold (without adjusting the tune)? I saw 1 or 2 people say on the camaro 6 facebook group that it is running a little lean at wot up top. Not sure if that’s true or not but if it is, my LT2 manifold that hasn’t been installed yet is about to be for sale.
m6-lt1 is offline   Reply With Quote
Old 09-25-2020, 11:29 PM   #219
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Since the LT2 manifold is most likely to only increase volumetric efficiency at higher rpms (>4000rpms) you won't have any problems. The stock calibration completely relies on the MAF sensor above 4000 rpms and as long as you haven't messed with the MAF sensor or have a aftermarket air intake that has a modified MAF tube then the MAF sensor will pick up the extra air and tell the ECM to increase fuel accordingly.
After my LT2 manifold install I never noticed any significant difference and my target AFR was still good at WOT.
cmitchell17 is offline   Reply With Quote
Old 09-28-2020, 08:10 AM   #220
m6-lt1
m6-lt1's Avatar
Thanks! I wanted to hear from someone’s who’s afr didn’t change. Before installing the manifold. Not sure why someone else’s did. My car is bone stock so I guess it shouldn’t change or change much.
Old 09-28-2020, 09:23 AM   #221
chaospiece
Drives: 2018 SS, 2016 GT
Also depends what other mods they have.
You can't just start compounding minor mods together and expect to always be fine. Stock tune and lt2 would probably be fine, the car will adjust but once you start adding throttle body, bigger intake tube, etc, things change.
chaospiece is offline   Reply With Quote
Old 10-09-2020, 04:55 PM   #222
6spdhyperblue
Drives: 6th gen
Update
Old 10-09-2020, 05:00 PM   #223
BlackbeastSS2
Update
Very Nice! I order the same one and can’t wait till it’s delivered. 95mm is on.
You can put those hoses underneath TB.
Old 10-09-2020, 06:30 PM   #224
6spdhyperblue
Drives: 6th gen
Cool I’ll try it. got it used off corvetteforum
