01-24-2021, 04:01 PM | #1 |
Patriot
Drives: 2019 Camaro 1SS 1LE Join Date: Sep 2020
Cluster glitch issue.
Does anyone else get or seen an issue like this. Cars driving fine and the gauges all glitch out together. I get the noises for low fuel indications for fuel low, power steering, suspension, etc but it’s only for that half second. And only the indications. Car operates fine isn’t low on gas power steering never quits working or anything of the sort. See video
Couldn’t get it to load in files so here’s a link to it on my Instagram. Follow my page while your there lol. https://www.instagram.com/p/CKcZYhpF...id=n87n96kyimv |
01-24-2021, 04:19 PM | #2 |
Drives: 2016 2SS Join Date: Apr 2020
My rpm gauge goes crazy. Started doing it once in a while, seems like it does it damn near every time I drive the car now. It seems my issue is the ground by the fuse cover under the hood based off everything I've read here. Not sure if it's the same issue you're having since you have a 19.
I ordered the ground cable from Lethal, going to add that and hope it helps, even though technically its supposed to be for the slow crank issues I believe. Going to add another ground at the battery as well. |
01-24-2021, 04:37 PM | #3 |
Patriot
Sounds plausible. Like a ground breaking contact hitting a bump or from the shake of my cam
