05-27-2022, 08:34 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2021
Ethanol question
I’ve got a Kong x port, headers, 103 throttle body, 2.3” upper pulley, running on 93 octane. If I went back to a 2.5” pulley and added a jms boost a pump, would I be able to run any appreciable amount of ethanol with that and the stock high side? I’m at about 700 feet elevation.
05-27-2022, 08:50 PM | #2 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I believe maybe e30-40 but you’d really just have to log it or have your tuner verify it on dyno. There are a couple guys on here that probably have direct experience and can give you a more accurate prediction.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
05-27-2022, 08:55 PM | #3 | |
Low side fuel pressure High side rail pressure Injector pulse width Or, just ask KingLT1 since he probably knows the numbers off the top of his head.
05-27-2022, 09:36 PM | #4 | |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
05-27-2022, 09:50 PM | #5 |
Thanks, I’m trying to figure out it if would be worth doing. I don’t have a flex fuel sensor yet, either. Maybe this winter I’ll do injectors and big bore pump like you? I’d rather do that than a cam, but my car is in the dreaded oil pump failure zone. Might make sense to go the cam and oil pump route?
05-27-2022, 09:54 PM | #6 |
I did the work. Had it dyno tuned. It’s an automatic. Made 644/614 STD on a dynojet. I believe it was run in 6th gear. No baseline, unfortunately.
05-27-2022, 10:09 PM | #7 | |
05-27-2022, 10:24 PM | #8 | |
05-27-2022, 11:50 PM | #9 | |
Drives: HBM ZLE Join Date: Aug 2017
05-28-2022, 06:28 AM | #10 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
If you're in eastern Ohio you might check out CSP. It might not be that much farther a drive to their shop as the drive to Cincinnati.
05-28-2022, 10:39 AM | #11 | |
If you did XDI +30' and a LPE hpfp, you could get up over E60 with a stock pulley. We are running a Kong standard port with 2.17 pulley on E60 with the fuel system above. Has all the other supporting bolt's...headers, cai, 103mm tb...etc. It made 700/660 SAE on a Mustang Dyno that reads about 5-6% lower then a Dynojet. And I agree about having somebody tear apart a perfectly well running engine. Which is why I would rather spend money on fuel system to run E over doing a cam and 93. You don't really need a cam to make good power with these engines anyway. Not saying a cam is a bad choice because at a certain point it is definitely needed. But for builds under 800whp it's not. Full bolt's, fuel system, E, Xport or bigger supercharger, will make more consistent power then you will hook on the street without a full drag pack on a prepped surface anyway. The 1000whp shit is just for internet/local car club bragging rights. I have timing pulled out through the mid range on my brothers H/C 2650 Z06 M7 . It made 900/780 on the same Mustang Dyno with 3 mph of wheel spin. Took 6 pulls, lots of stripper glue, and other tricks to get it from 21mph wheel spin to 3mph. First pulls was 760/780whp spinning. That was with a Hoosier race tire. The thing is nuts and he wants to turn it up more. lol
2016 NFG 1SS A8
05-28-2022, 12:21 PM | #12 | |
05-28-2022, 09:54 PM | #13 |
Drives: 2017 ZL1 Join Date: Aug 2020
On a mustang dyno with LT's, 19% lower, bg, kooks and 45% e and a jms we were making 688whp.
Made the mistake of going to e60, leaned out 2 cylinders and boom. It would have been much cheaper upfront to address the fueling than rebuilding the engine. Expensive lesson. |
05-30-2022, 11:22 PM | #14 | |
